Old 02-16-2011, 03:30 PM
N73JE's Avatar
N73JE N73JE is offline
Default Are screw dimples special?
I'm getting my tools assembled and was looking over the tool list on Van's website.
I see the usual 3/32" Rivet Dimple Die and 1/8" Rivet Dimple Die. I also see #8 Screw Dimple Die. And in the forums I have read that a #10 Screw Dimple Die will be required as well.
Is there something different about a "screw" vs "rivet" die? Are the screw heads not at 100 degrees or something?
I was looking at buying the dies at "The Yard":
http://www.yardstore.com/browse.cfm/2,405.html
They are all 100 degree "spring back" dies and seem well priced.
Also, are 3/16" Rivet Dimple Dies the same as #10 Screw Dimple Dies?
Inputs?
Thanks!
Jason Ellingson
N-Num: N73JE
Model: RV-8A
Stage: Inventorying Empennage Kit
Track: http://www.mykitlog.com/Ellingson/
I donated to VAF; I hope you do too.
Last edited by N73JE : 02-16-2011 at 03:35 PM. Reason: Added question about #10 screw dimple die
Old 02-16-2011, 04:53 PM
noelf noelf is offline
The dimple dies produce a 100deg dimple, some special dimples dies are for 110deg blind rivets.
If you drill the proper sized hole for an AN-xxx screw, and try to use a rivet dimple die, there is no real way to get the dilple die centered in the hole for a "centered" flush-head screw. The same goes with trying to use a #6 dimple die for a #10 screw.
Old 02-16-2011, 04:56 PM
Mel's Avatar
Mel Mel is offline
Actually, pulled rivet heads are 120°.
A&P/EAA Tech Counselor/Flight Advisor
<n168tx(at)flytx.net>
North Texas (8TA5)
RV-6 Flying since 1993
175hp O-320
3-Blade Catto (since 2003)
FRIEND of the RV-1
Old 02-16-2011, 06:49 PM
N73JE's Avatar
Okay... so I got figured that both the solid rivets and screws we're using have a 100 degree head. The blind rivets have 120 degree heads. Cool.
Please correct my understandings below:
Universal (button) head rivets and Flush head rivets (countersunk surface):
-3 rivets use a #40 drill bit
-4 rivets use a #30 drill bit
Flush head rivets (dimpled surface):
-3 rivets use a #41 drill bit and 3/32" dimple die
-4 rivets use a 1/8" drill bit and 1/8" dimple die
Flush screws (countersunk surface):
#8 screws use a #19 drill bit
#10 screws use a #11 drill bit
Flush screws (dimpled surface):
#8 screws use a #20 drill bit and a #8 screw dimple die
#10 screws use a #12 drill bit and a 3/16" dimple die
Or am I not understanding correctly?
Jason Ellingson
N-Num: N73JE
Model: RV-8A
Old 02-16-2011, 06:55 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by N73JE View Post
...Or am I not understanding correctly?
Sounds about right. But don't forget #6 screws, you've probably got a handful of them to do as well.
HP-24 kit sailplane project
http://www.hpaircraft.com/hp-24
HP-24 project on Facebook
Old 02-16-2011, 07:36 PM
N73JE's Avatar
Ok, adding the #6 screw to my table gives me...
#6 screws use a #28 drill bit
#6 screws use a #29 drill bit and a #6 screw dimple die (no substitute)
#8 screws use a #20 drill bit and a #8 screw dimple die (5/32" dimple die is a close substitute)
#10 screws use a #12 drill bit and a #10 screw dimple die (3/16" dimple die is a close substitute)
Still looking good?
Jason Ellingson
N-Num: N73JE
Model: RV-8A
Last edited by N73JE : 02-17-2011 at 07:49 AM. Reason: Updated #8 and #10 dimple die substitutes
Old 02-16-2011, 08:25 PM
terrye terrye is offline
Default Dimple Dies
Yep, pretty much what I am doing except I use #40 and #30 drills for both universal head (AN470) and flush head (AN426) rivets.
Old 02-16-2011, 09:46 PM
fehdxl fehdxl is offline
FWIW, I have to make a #18 hole to dimple for a #8 screw...might just be my dimple die though. I too use #30/40 holes for -3/4 rivets irrespective of flush or not.
Also, please note that you really want to make sure those #8 and and #10 screw holes are smooth and de-burred well before dimpling. Don't over-do it...but just get it right. There's a lot of bending and stretching going on and the chances for cracks around the dimple edge is higher than the smaller holes.
Just my observations.
Best to you,
-Jim
Old 02-17-2011, 05:56 AM
N73JE's Avatar
Best to you,
-Jim
Thanks for the advice. I actually didn't think about that. Perhaps a light deburr before dimpling and another just after? Just in case a stress point is made?
Jason Ellingson
N-Num: N73JE
Model: RV-8A
Old 02-17-2011, 01:04 PM
Auburntsts's Avatar
IMO you're making this more complicated than it needs to be. You don't need seperate sizes for dimples vs. CSKs (unless the pilots on your dimples and CSKs aren't fitting through the holes). Here's what I use with no problems whatsoever:
#40 drill bit for all -3 rivets (426 and 470)
#30 Drill bit for all -4 rivets (426 and 470)
#28 drill bit for #6 screws
#19 drill bit for #8 screws
#12 drill bit for#10 screws
The advice to ensure the #8 and #10 holes are well deburred before dimpling is spot on.
YMMV...
Todd Stovall
Aka tsts4 on POA & Matronics, and Auburntsts on AOPA, RV Airspace, EAA, & Purple Pilots
N728TT
RV-10 Empacone, Wings, Fuse, Finishing
My builder's log (which is woefully out of date): www.mykitlog.com/auburntsts
Dumfries, VA (suburb of DC)
WAR DAM_ EAGLE!
