The radiator and scoop were placed here for a variety of reasons- close to the C of G, water piping concerns, structure to attach to, ground cooling, frontal area of the scoop and CFD studies with regard to exit flow. This placement was the best overall compromise.
I use a horizontal splitter plate mounted just below the stock cowling air exit. This keeps hot air from the cowling from entering the rad scoop. The stock cowling exit shields about 35% of the rad scoop frontal area.
Many different rad mounting concepts were evaluated including completely submerged ducts with twin rads mounted aft of the baggage bulkhead however piping water lines through the structure and cutting holes for NACA ducts would create some serious structural concerns. Ground cooling would almost certainly be marginal as well.
With the turbos and intercoolers, there was no way to mount the rads up front in the cowling properly. I'm not a fan of mounting rads with the fins perpendicular to the freestream. All my testing with flow bench models show this is a high drag solution.
