Review Section 4 (Parts Index) against the plans and try to annotate type specific parts (both 8A and 8). The Drawings are sometimes labelled RV-8A or RV-8, but I found that somewhat unreliable i.e. even an RV-8 sometimes had sections on the RV-8A pages you needed.
Might be worth asking Vans to send the "parts lists" for the 8 and 8A Fus kits, and then manually compare them?
Finally, as you do build up a definitive list, it might be worth filing it somewhere on line / referenced from here for others with the same issue in future?
Andy & Ellie Hill
RV-8 G-HILZ
RV-8tors
