ErichKeane
I've been going over the wiring in the plane, and noticed that the wing-spar sensors are too low! The clamps that hold them into place made them sit too low to register properly. The wiring works correctly, and I can get them to go green when I hold them in place against the top, but when clamped in they are quite a bit too low.
I took off as much steel from the pin as I dare (just about the 1/8th"), but it didn't fix it.
I also removed the rubber from the back of the clamp to raise it that little bit, but that still didn't help.
Anyone have any other ideas/fixes?
