I had a low cylinder this week, 62, after borescoping it, found nothing, checked the dry tappet clearance and found it out of limits. Decided to pull the lifter from the exhaust side. It had some "gunk" in it that was keeping the valve from fully seating. Clearance range is .028-.080 and I had .012 to start, .033 after cleaning the lifter. Rechecked the compression cold and it's 68 now. Haven't run it yet to get a hot check (still on jacks doing wheel pants), but I suspect that after I fly it five hours or so, it'll be in the 70's again.
