While awaiting delivery of my avionics I have delved into a few tasks preparing for the move to engine installation and fitting up the cowling. With a bit of enthusiasm I pulled out the long-stored cowling halves and examined the fit of the front face. I placed a straight edge across the bottom cowl at the base of the joggle and discovered quite an asymmetry. The face to be positioned a nice 1/4 inch aft of the spinner is tilted laterally:
As you can see form the photos, the sides are of equal height at the level of the air inlets; the tilt seems to be entirely in the central flanges. The top half of the cowl matches this tilt even though the two pieces are of two different tints and appear to be of different ages.
My question is this. How would experienced cowl fitters proceed? I am preparing a 13" wooden disk, as Dan H has so nicely demonstrated, to assure proper size of the opening and establish a horizontal separation line but what to do with the tilt?
I see two choices: leave it as is for now and correct the tilt after fitting the cowl; or attempt to cut and level the individual halves before fitting the cowl. (I believe the tilt is too great to try to heat-shape and that would render the air inlets asymmetrical.)
The group's thoughts/advice would be welcome.
