Heat and Location
(First of all, I apologize for posting a pic of an RV-7 installation in an RV-12 thread. RV-12s have to be built per the manual!)
Walt,
You make good points about the FWF heat, and putting the cap as close (electrically) as possible to the noise source.
As for the FWF heat, I can't argue about the temperature - I don't know how hot that area of the engine compartment is getting - but the cap has been flown in OAT up to about 100F, altitudes up to 17,750', and looks as good as new.
As for the electrical noise, when I installed the cap, I simply wanted to provide a "sink" for any stray noise in the system. The wiring runs are all relatively short - maybe 10' of wire max from the battery/alternator to each of the loads, so the cap is (electrically) very close to each of the noisy loads. Since I don't experience any noise, I haven't felt the need to relocate the cap.
FWIW - noisy loads are going to be the Strobe power supply, the Alternator, the Fuel Pump, Trim Servos and Autopilot Servos, and Magneto P-Leads.
