Greetings fellow RV-10r's
I am building an RV-10 and strongly considering Hotel Wiskey extended range tanks.
I have a couple of questions for those of you who are flying with them.
1) How do you determine how much fuel is in your extended range tanks?
2) What if I mistakenly activate the fuel pump from the extended tank while my stock tank is still full? Does it push fuel out the vent tube?
3) If I install your tanks does this negate the use of the Archer wingtip VOR antenna?
Does anyone have any info on just making the stock tank occupy more of the leading edge?
