Old 03-15-2011, 11:58 PM
JackW JackW is offline
Default Getting Closer
Finally (nearly) finished the cockpit yesterday. Couple of images attached...
John Bridges
Riddells Creek (YRID)
near Melbourne, Oz
VH-VNS, RV-6A, IO-320
It flies!
Old 03-16-2011, 06:00 AM
pierre smith's Avatar
Default Beautiful, John..
....and as I said earlier....Experimental Aviation is raising the bar for the certified crowd!
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15
Air Tractor 402 PT-6-20
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-16-2011, 11:13 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by JackW View Post
Beautiful. I have to ask...do you have a better picture of the center of your panel? Specifically (CB/push buttons?) above the throttle/mixture. Info on those would be great.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-16-2011, 06:20 PM
Carlos,
The switches are DPDT with a separate circuit for the LED ring. LED can be lit for either switch on or off. These switches are only rated at 3A@250V but that isn't a problem here because they are connected to a VP-X so only grounding a circuit to earth for the VP-X. The issue with that is I needed a separate power supply for the LED rings. Not a big deal with the VP-X though. The switches are IP67 rated.
If interested, the three knobs on the sub-panel control, via-RC servos, the heater and baggage area vents (which the boss wanted installed for the dog's pleasure). The third knob is the panel dimmer. The vents are the small rectangular RV10 rear vents.
John Bridges
near Melbourne, Oz
It flies!
Old 03-17-2011, 08:35 AM
rleffler's Avatar
rleffler rleffler is offline
Carlos,
What's the vendor and part number for your switch?
thanks,
bob
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 03-17-2011, 05:31 PM
thanks,
bob
Bob,
Local in Oz from Jaycar Electronics but it appears to be similar to these: http://www.e-switch.com/product/tabi...s/default.aspx
Only difference I can see are the rating but 2A@48V is fine if connected to a VP-X.
John Bridges
near Melbourne, Oz
It flies!
Old 03-17-2011, 06:42 PM
eh_v8_tor's Avatar
eh_v8_tor eh_v8_tor is offline
Cool Very Cool Switches!
Very Cool switches!
If I use the VPX or some form of it, then I'll be a big old copy cat and use the very same switches.
Thanks for your post!
Steve Wolfe
Old 05-28-2011, 06:04 PM
db9469 db9469 is offline
Default Another fuselage flipped!!
Finally!! Got my fuselage flipped today. It took almost a year to build (built the fixture 6/5/10) Spent most of the last month recruiting bucking bar holders. Thanks to Wilson Whitt and Glenn Chapman. Still would be scratching my head staring at it if it weren't for them.
Old 05-28-2011, 06:12 PM
Old 05-28-2011, 06:13 PM
