Had an interesting experience this weekend as I changed the brake lines on our RV-4 (which I did not build)...Brett at Bonaco did a great job of building new braded lines, and I dutfily built the requisite pump assembly using appropriate fittings and a garden sprayer, shamelessly copying the design elsewhere in the forums...
...After a couple of hours and recirculating over a gallon of fluid through each side from the bottom up, no pedal pressure (at least I was positive I flushed all of the 5606 from the system and replaced it with 83282!)--lots of head scratching and well meaning advice. Pumping the brakes down like an automobile? No pedal pressure and more head scratching. Call to Van's Tech Support--the master cylinders in the RV-4 are upside down, bleeding can be sporty...total head scratching time, well in excess of four hours...
...Disconnected fancy spray bottle from bleed screw, removed the line and fittings and plumbed it to the overflow hose fitted to reservoir. Pumped up the pressure, opened the valve, put a container under the bleed screw and bled each side in less than a minute.
"Bottom up" bleeding works great when the cylinders are right side up, but if they're upside down, top down may be warranted/required. You can also save the expense of the fitting designed to fit the bleed screw, a clean shallow container is all thats required. When the reservior is being fed by a pressurized system, there's no doubt when air is escaping at the bleed screw, the fluids spits out rather than flowing smoothly. The stock Van's reservior takes a 1/8" NPT fitting, and an appropriate length of clear tubing is all that's required to hook it up to a pump.
It was also interesting that with the pressurized container hooked to the reservior, the pedals where nearly rock hard--like having power brakes. When the hose was removed and the vented cap replaced, the pedal pressure returned to normal.
Vac
Vac
