cfiidon
I'm at the stage where I will installing engine sensors. I've read as many threads as my eyes can handle, and I think I have a handle on it. However; I'd feel better if I got some warm fuzzies from those in the know.
Reference the picture below: I'm planning to hook up my oil pressure sensor thru a manifold with a hose and fitting to the port marked with the red arrow on the oil pump. I'll use a 45 degree (to clear the engine mount) fitting and install a restricted orifice.
The oil temp sensor will go in the oil filter bypass port marked with the green arrow. Sound right? Alternative ideas?
[/URL][/IMG]
Now for the fuel pressure sensor. I was thinking of using some sort of "tee" to tap into the unmetered fuel line where it exits the fuel pump. Not a great picture, but see the photo below with the yellow arrow, which points to the brass elbow with fuel line attached. This too will go to another port on the manifold. If anyone has a hardware combo idea and source handy I'd appreciate it.
For reference, I have an ECi XIO-360 with an AE fuel system.
Don
Don
