lostpilot28
I finally got around to using the UV dye and flashlight to find the oil leaks in my engine. I bought the stuff at Autozone for $20. $6 for the dye, and $14 for the UV flashlight and yellow goggles.
Anyway, I ran the engine for 15 min. to get it up to operating temps (wasn't hard to do since it was 100 degrees today), then put the airplane in the hangar to look for leaks. I found a few small ones. One (each) of the pushrod tubes for #1 and #3 cylinders appears to have a very slight leak at the crankcase. The rubber gaskets don't appear to be doing their job. Is it OK to use gasket sealer on these?
I also found a slight leak on the copper nut on the bottom of the #3 cylinder. Actually, that one started leaking from day 1. I've never been sure how to stop it, so I just left it. Any ideas?
There were also a couple of flourecent spots around the rubber hoses connecting to the oil drain-back lines. This surprised me since before doing any of this I re-tightened all the hose-clamps I could find. I'm wondering if anyone ever adds a slight layer of gasket sealer to these?
The only other thing I did was re-do my crankcase breather hose. I wasn't happy with it before, and ended up making the new one exit the cowl like a mini-exhaust pipe. I'm really hoping this creates a negative pressure and slows, if not stops, my leaks. I'll report back with the results after I fly it a couple hours.
