Addicted to the site?
Donate yearly (please).
Advertise in here!
Today's Posts | Insert Pics
Old 07-13-2010, 11:49 AM
David-aviator David-aviator is offline
Default New Runway - First Flight
Yesterday the final layer of asphalt was laid and we decided to reopen flight operations today even though there is some work remaining to prepare the new grass runway for seeding. We have been shut down since June 24.
I asked a couple other guys if they wished to make the first flight and both declined, so I had do it my self.
The runway slopes down hill to the west but with a light southeast wind, it had to be an uphill launch to the east.
What a difference, that used to be a bouncy take off, now it is smooth as a baby's bottom. Even with the slope, the RV was off in 720' with a FP prop turning up just 2170 rpm.
Grass operations is charismatic and all that stuff, but I will take performance any day. A smooth surface does make a difference. When the wind shifts to west, the RV will be off in 500' hands down. I like it.
David Domeier
RV-7A N707DD
Barrett IO360-X
AFP FI
Vetterman 4 pipe (Harley) exhaust
Catto 3 Blade 66x74
Troy, MO
Old 07-13-2010, 09:16 PM
aerhed aerhed is offline
David, I'm assuming this is private? If so, can you tell me how long, how thick, what you did for base, & finally mas importante, que dinero?
Old 07-13-2010, 09:33 PM
7pilot's Avatar
7pilot 7pilot is offline
Default 2170 RPM?
Originally Posted by David-aviator View Post
...the RV was off in 720' with a FP prop turning up just 2170 rpm.
Just curious... why only 2170 RPM for takeoff? Why not full power & full forward on prop?
Stewart Cole
N156DE RV-7A Tip-up, IO360 CS MT Prop
http://www.7pilot.com
Old 07-14-2010, 04:44 AM
rodrv6's Avatar
rodrv6 rodrv6 is offline
I believe he has a fixed pitch (FP) prop..........
Rod Schneider
Woodstock, Ga
RV-6 Slider, Eggenfellner H6 Subaru
N164ME Registered!
Prepping to move to the airport!
Now, to get myself ready..........
Old 07-14-2010, 04:55 AM
plehrke's Avatar
plehrke plehrke is offline
I flew recon over it last Sunday and saw it look like it was getting ready but had "X" on it. I took a few photos and was going to post but never got around to downloading the pictures. Glad you are now flying off it. Will Charlie use the asphalt with the Luscomb?
Based @ 1H0 (Creve Coeur)
RV-6A - Flying over 400 hours
Cessna 140 - in Restoration
Old 07-14-2010, 07:42 AM
It is private. The finished product is 2170'x25'.
I've learned much, mostly from the asphalt company co-owner who has taken a personal interest in the project. The key to a satisfactory, smooth runway is base preparation.
We have an excavated area of 27' wide by some 11" deep on average considering leveling some high spots and filling some low spots. The final cut of the excavated area is made with a road trimmer (also called planer) at a specific depth and gradient angle referenced to a string line attached to metal posts along the side of the runway. That string reference is adjusted every 50' to smooth gradient variations and is set considering where we want the runway elevation to end up.
Then 8" is base material is filled in and spread over a stabilization fabric with a high lift and rolled with a 10 ton roller. This base material packs like concrete, it is 1" rock mixed with much smaller particles of varying size. Then the trimmer comes back in again and makes another pass leveling and setting the grade. On top of the fill goes 3" of road asphalt, the grade is BP-1 or 2. The actual amount of asphalt is greater than 3" as it is rolled to end up at 3".
A runway can be built using a high lift and standard grader, but even the most expert grader operator can not match the precision of the trimmer machine. The trimmer machine has a 16' rotary cutter that is controlled by a hydraulic system referenced to the guide line. There are various rotary cutters for dirt or asphalt cutting.
I learned that the price of asphalt is controlled by state government in most states. They set what is know as an asphalt index each month. This was started some years ago when the price of oil was making huge swings and no one knew what a project would end up costing. Now the price is set for at least 30 days.
The cost - we have a contract that includes filling, rolling and trimming a grass landing area adjacent to the hard surface with a smooth transition from grass to asphalt and vice-versa. The final bid number is based on square yards of asphalt and came in at $25.55/yrd, or approximately $155,000. (The included grass area prep is about $14,000 but does not include seeding.) The final cost will be determined by actual yardage of asphalt installed and the state index. As a friend commented, you can not get good carpet installed in your home for $25.55/yard, what a deal!
The price of the project could have been reduced without using the trimmer and without grass area preparation. But a primary objective here was to end up with a smooth runway, not a repeat of what we had. We considered a complete redo of the grass landing strip but that would have cost $80,000-90,000 and we still would have a mess over the winter months.
It will take about a year to get the new grass area seeded, growing and settled but it will be much better than it was.
As of right now, local residents are quite satisfied how this is turning out.
David Domeier
RV-7A N707DD
Barrett IO360-X
AFP FI
Catto 3 Blade 66x74
Troy, MO
Old 07-14-2010, 07:45 AM
Don't know if he will or not. At present he is busy building another airplane, one of the Murphy models, in his basement.
The runway is open, Phil, but for now restricted to local residents only due to all the equipment still on the property.
David Domeier
RV-7A N707DD
Barrett IO360-X
AFP FI
Catto 3 Blade 66x74
Troy, MO
Old 07-14-2010, 08:27 AM
David, thanks. That's really informative. I've been involved in public runway expansions, but that's a different deal ( big fed dollars/big aircraft ). One of my customers put in his own 5000x50 asphalt on the Green River, but he's so far out of my league it' not worth asking.
