Brantel
It seems that the newer baffle design is no more immune to cracks on the aft rear baffle when the oil cooler is mounted there than the old one...
Anyone not flying yet, do yourself a favor and beef this area up before flying!!!
I was naive and built mine per plans thinking the new brace design might solve the problem....wrong! Within 25 hrs I started seeing cracks in the corner. My prop has been dynamically balanced and the engine runs smooth. I have kept a close eye on the issue and it is soon to be repaired. I just purchased the $60+ worth of replacement parts in order to rebuild the aft rear baffle.
I plan to beef this area up greatly and add an angle brace.
If you have good ideas for beef up that you would like to share with me and others to come, please share them with us....
After contacting Van's about the fact that their baffle kit design is almost guaranteed to fail if built per the plans, the reply was something like we know it stinks, do the best you can with it, hopefully you will come up with a solution that will work for you, it is not our problem....not the best answer!!!
