ww2planes said:Has anyone installed a blade style pitot? Are there any problems with using one on a RV? I like the look a lot better and have already purchased one. Polished it and it really looks good. Any input would be greatly appreciated.
I hate asking the obvious (may be not so obvious), but I can't stand it, why do you want a heated pitot tube at all? I know it sounds stupid, especially from a CFI-I-ME, ATP with a few type ratings, but why do you want a heated pitot on a single engine sport plane that is prohibited from being in icing conditions. Do you plan on flying in icing?ww2planes said:Has anyone installed a blade style pitot? Are there any problems with using one on a RV? I like the look a lot better and have already purchased one. Polished it and it really looks good. Any input would be greatly appreciated.
gmcjetpilot said:I hate asking the obvious (may be not so obvious), but I can't stand it, why do you want a heated pitot tube at all? I know it sounds stupid, especially from a CFI-I-ME, ATP with a few type ratings, but why do you want a heated pitot on a single engine sport plane that is prohibited from being in icing conditions. Do you plan on flying in icing?
I don't begrudge people building what they want, but I wounder sometimes why so many want a heated pitot. I really don't get a VFR pilot needing a heated pitot on their plane. Even IFR, ice should be a rare event, at least if you plan your flights right, i.e. safe and legal.
They are expensive, draw copious current add weight and the amount of time you might use it, is......well questionable. I relize many are drawn to them because they like the looks, since the standard "TUBE" is plan, although arguable very functional, light and inexpensive. Make a fake one out of fiberglass or metal of any cool shape you want for a few bucks.
Lets go out on a limb (and you would be). You find yourself in icing conditions. Some how it gets so bad your pitot is blocked and thus your airspeed indicator is dead. You still have approximate speed from GPS ground speed. Of course you're solid IMC now, on instruments. You need to get out of it NOW, both from a common sense and legal stand point, right. In my opinion (and the FAA's) if you're getting airframe ice you are not only illegal you are in a dangerous condition, even with pitot heat. Once you see ice it is "KNOWN ICE", at least now.
How do you get ICE? Any takers?
Ans: Visible moisture and temp below 0 C. Period end of story. Stay out of clouds or temps below 0 C (and above -40 C) no ice. If there is no clouds, mist, fog (defined as visibility of say less than 1 miles) no ice. If temp is above 0C no ice. It is that simple. NO ICE. You can't form ice unless you are in a cloud below 0C. (Below -40C there's not enough moisture to cause icing.)
Someone might say "freezing rain" (I coverd it with visible mosture). If you are in freezing rain, you're in trouble. Don't worry about the pitot. You'll have no lift or thrust when the wings and prop ice over. In this case heated pitot will only help you to see indicated airspeed on the way to the scene of your crash.
If you plan on flying IFR routinly than the value of a heated pitot is better justified, but its not required IFR equip! I am surprised how much effort and expense builders put into a heated pitot for VFR RV. If you are a VFR pilot and wondering into clouds in freezing conditions, you have more troubles than pitot ice.
Suggest builders evaluate if they really (really) NEED a heated pitot. If not sure, run some wires out the wing and put in one of those fake heated pitot ( http://www.gretzaero.com/ga500.html ). You can replace it later with a hot one, if you so decide. Just a suggestion but if you have to have a heated pitot you have to have it. However weight on RV's is important and the lighter the better. Its just a thought.
George
There are a lot of RVs flying with one of the various Piper blade pitots. The pitot part works just fine. The static source will probably give errors, so don't bother using it.ww2planes said:Thanks everyone for the input. Most of it is not applicable as I never mentioned anything about a heated tube. I just want to know if anyone has any experience with the Piper Blade Style Pitot. Non-heated, non-dynon, just plain blade style pitot. If anyone has any input on this specific question I would love to hear it. Thanks everyone.
The type of error that static source position error gives is not detectable by a static check on the ground. The check on the ground checks the accuracy of the altimeter and altitude encoder. Static source position error is caused by the air pressure at the static source differing from the free stream air pressure. This happens because the air accelerates and decelerates as it wends its way over the curves of the airframe, and Bernoulli tells us that the air pressure changes as the air's velocity changes. But this error is not present if the airspeed is zero.Chino Tom said:I have a heated Piper blade on my RV-6. I have no issues with either the pitot or static function. Every 2 years it gets a IFR Pitot/Static check. Maybe I'm a lucky one.
Tom,tin man said:I've been using one for 900+ hours and have not had any problems, have system checked every 2 years, even cross checked with a CAFE calibrated RV4 and system was right on.
Kevin Horton said:Tom,
Are you using the static source on the blade? If so, it would be interesting to get the part number of your blade pitot, and the exact location you have it mounted. Is it mounted sitting flat on the wing skin, or is it angled forward or aft at all? All those details are important if someone wanted to try to replicate your installation. Small differences in location or angle will affect the pressure sensed by the static port.
The pitot pressure is not sensitive to location or mounting angle, or probe part number. It just has to be mounted so it is clear of the prop wash, not in the wake of anything else, and so the pitot port is out of the boundary layer (you would have to recess the base of the probe into the wing to cause problems with the boundary layer).
Thanks mho for such a tactful well thought out reply. Opposing opinions, especially such polite ones are alway nice.johnp said:i'm also going to disagree with george on this issue. i have experienced pitot ice in imc on three occasions (that i can distinctly recall) in the last 20 or so years -- only one of which was accompanied by any sign of airframe icing. it wasn't fatal in any of them (i think.)
why would i not want to add something to help ensure i have the bare minimum in case of catastrophic failure of the other stuff?
i might go on to say that the probable reason i haven't had pitot icing more than those three times is that my checklist now includes "entering visible moisture -- pitot heat on". i don't have the studies to show it, but i believe that pitot icing can easily form in conditions that are not conducive to airframe icing, having experienced this twice myself.
i respect most of what george has to say, but i reserve the right to disagree with him on this.
mho,
I have never been reported by ATC at an altitude other than what I was indicating on my altimeter.
Low altitude fly bys are a recognized flight test technique to determine static system error, but you need to couple them with some sort of photographic method to accurately determine the actual altitude on each run, and you need some method to accurate record the indicated altitude at the moment the photo is taken. All in all it is not practical to use this method unless you have access to resources that most of us don't have.4kilo said:This is what Keven H. meant about accurate static checking being rather difficult to accomplish. You might be able to get a rough idea by doing low altitude fly-bys of a runway at various speeds and noting the indicated altitude, but this is neccessarily a rather imprecise method. To get any really decent data, you would probably need to trail some sort of static bomb (lots of work for a rather small return).
