I am at the point of mounting the oil cooler. Baffels are fitted and cut down to size. I drilled the CB-705B oil cooler brace to the baffel placing it such that I can get the oil cooler mounted as high as possible. Now I find that I need to cut the rear most flange of the oil cooler to clear the engine mount right where the center mounting hole is located, one of two available to attach the cooler to the baffel. This would negate the use of the long bolt and spacer at this point. It appears that the solution is to use a shorter bolt that would secure only the inside flange (the flange sits against the baffel) to the baffel. Is this an acceptable solution. Is it ok to just use the inside flange only to attach the cooler at this point.
