Brantel
On another thread I mentioned that on my last flight that I thought that the reciever sensitivity was slowly reducing over the period of 2.5 hrs on my A210. The first of the flight and all flights before were normal but about an hour into this flight I started having trouble hearing people and had to be real close to airports to get the AWOS.
Upon landing, I checked the SWR of the antenna and feedline and it was normal.
Anyone else ever notice this?
I might have an issue with my A210 as last flight it seemed that the reciever lost some sensitivity as I had to be on top of the airports to get the AWOS and noticed that I was having problems with hearing people. After the flight I checked the SWR and it was good so I am not sure what was going on???
Hi Brantel,
I have seen the same problem on my A210. I found that if I turn it off, then turn it back on, the reception is back to normal for a time. I sent it back to get checked out, but they said they could find nothing wrong. But it is still doing it. Be interesting if my fix works for you too.
I saw this once when the plane was in my basement and it also went away after a power cycle....I did not think to try that while in flight.
I have a theory that it might be the ANL feature doing it since I have that turned on. I am going to disable that and see what happens...
What else could it possibly be?
