donaziza
Maybe 2 years ago, I asked about bailing out of an RV 8. (Let's say you got a roaring fire or a wing came off doing acro, or a flat spin). Some people said due, to pressure, one couldn't get the canopy open in flight. ( Vans didn't know). I think it was Paul Dye who said "remove the bolts on the forward left & right posts on your canopy, and put some Pip pins in instead. If you're wearing a parachute, remove the pip pins before takeoff. This way if the dreaded situation arose, simply crack the canopy open, push up one inch ( as the bolts and pip pins have been removed), and the slip steam will rip it of the airplane. Also roll inverted and push on the stick to get yourself out.
OK, now for the question.I don't guess anyone is going to know the answer to this, but I've gotta ask anyway. Suppose you've got not a fire or wing departure, but an engine failure, and the only place to land is on water. I'm told that generally small airplanes flip over on hitting the water. ( Official safety Pub). Wouldn't it be nice to have already rid yourself of that canopy!! BUT---if you get rid of your canopy in the way I've described, I'm "assuming" the small rubber piece that holds the back of the canopy on it's rail would simply rip off,---but what would it do to the vertical stabilizer??? If the vertical stab came off, that's just going to ruin your whole day on that nice power off glide you had all set up to the water.
