Old 02-15-2006, 11:53 AM
DeltaRomeo's Avatar
Your host.
Default New Builder Hints
...idea emailed to me by Terry Ruprecht. Great idea for a thread
RV Beginner Builder Hint #1:
When a small shiny tool rolls out of place on the work table, do NOT reach over lightning-like and move it back by the shiny end. It may be a soldering iron.
RV Beginner Builder Hint #2:
Unusual smells in the shop may include burning skin.
Old 02-15-2006, 12:12 PM
jcoloccia jcoloccia is offline
RV Beginner Builder Hint #3:
Always double check your drill bit size. For example, it's easy for a builder to confuse #12 and #21 drill bits, however the rivet you put in the resulting hole has an eye for such things and will complain loudly.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 02-15-2006, 12:27 PM
keen9a's Avatar
keen9a keen9a is offline
RV Beginner Builder Hint #4:
You're going to drill a whole in yourself at some point. Try to use a small bit, so it won't hurt as much. (I didn't!)
Ben Keen
RV-9 Flying 8/21/2016
http://www.pbase.com/benkeen/rv9
Old 02-15-2006, 12:35 PM
Davepar's Avatar
Davepar Davepar is offline
After you make two mistakes in a row, take a breather. Otherwise you're likely to make a third.
(We should put these in fortune cookies.)
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 02-15-2006, 12:37 PM
TJoyner TJoyner is offline
Beginner tip #5...
While using your cool pneumatic squeezer, never rest your finger on the trigger while dimpling, unless, of course an extra hole in a random location is desired..
TJoyner
Old 02-15-2006, 01:04 PM
DeltaRomeo's Avatar
Your host.
The new builder should be ever vigilant to not put the 1/8" male dimple die and the 3/32" female dimple die in the pnuematic squeezer - unless of course they want to buy a new die set and spend much time cursing.
doug reeves.
Organ donor card signed (use anything you need).
RV-6 flying since '02.
Old 02-15-2006, 01:27 PM
sf3543 sf3543 is offline
#7 Always disconnect the pneumatic squeezer from the air line while changing dies! ( I haven't squeezed/dimpled my finger yet, but just the thought makes me cringe.)
Old 02-15-2006, 02:24 PM
Jamie's Avatar
Jamie Jamie is offline
#8. Never prime parts with a subpar compressor...lest the internal compressor regulator fails and causes a chain reaction in which your spray gun trigger fails and instantly vaporizes all your primer that subsequently drifts down the driveway onto your wife's car. If you don't heed my advise you may end up stripping wax/washing/rewaxing your wife's car at 3 am on a weeknight.
#9. Always, ALWAYS wear gloves if you are working within one foot of the firewall. As they say...'like butter'.
"What kind of man would live where there is no daring? I don't believe in taking foolish chances but nothing can be accomplished without taking any chance at all." - Charles A. Lindbergh
Jamie | RV-7A First Flight: 7/27/2007 (Sold)
Old 02-15-2006, 02:29 PM
az_gila's Avatar
az_gila az_gila is offline
#10 ... at least the wooden homebuilt rule does not apply... "Don't bleed on the work"
Acetone is a good blood remover from expoxy primed parts...
gil in Tucson
Old 02-15-2006, 02:33 PM
dan's Avatar
dan dan is offline
#11 When somebody starts talking about primer, run for the hills.
Dan Checkoway RV-7
