jjconstant
I've finally edited the video of my first flight of RV7A N705CM. I'm 17 tach hours (triggered at 1500rpm) and 25 Hobbs hours into my 40hr Phase 1. Mattituch IO-360 vertical induction, WhirlWind 200RV constant speed prop, 1165lb empty weight. I'm flying out of Livermore, CA and my test area is a roughly circular 50nm radius range centered on the Modesto/Turlock area in the central valley. I've found flight following enormously helpful and reassuring while spending more time than I'm normally comfortable with "heads down" calibrating things and learning cockpit flows that work.
http://vimeo.com/11079276
It's about 5 minutes long.
Jeremy Constant
Jeremy Constant
