LettersFromFlyoverCountry
Generally speaking, if something doesn't work out the way it should on my RV project, I assume it's something I've done wrong. But this evening, I'm a little concerned that that may not be the case.
I was reinstalling the fat wires on the battery, to power up the Vertical Power 50 system and test out my long-running installation of the radios in N614EF.
When I dug the ground wire (from battery to firewall) out of the work cabinet, where I'd stored it since removing it a month ago, I notice one connector was missing.
This is the P9 wire, which I bought from Van's because I didn't really want to build these things myself. So for about $15 a pop, I figured what the heck.
I twisted -- slightly -- the other connector and gave it a slight tug and off it came!
Then I checked the P14 (battery to master), slight tug.... voila! Both ends.
I checked another Van's cable I had around -- a P14, I believe, and the connectors did not seem to twist off.
Because there's heat shrink on these things, you can't really tell much about their construction until they come off, but I see no signs of solder and no signs of crimping. It looks like they just slapped a connector on, slapped some heat shrink on, and mailed it out.
Is this the way it's supposed to be? It's got me a little spooked that I could've been flying around, and had some pretty important cables fall apart.
