Old 03-23-2010, 10:18 AM
Bugs66 Bugs66 is offline
Default King KLX 135A Wiring Diagram needed
Greetings,
Does anyone have the King KLX 135A GPS/COMM installation manual or wiring diagram? This thing has a million connections on the back. Would appreciate a scan of the wiring diagram. Thanks in advance.
Old 03-23-2010, 11:27 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Default connector pinout
http://www.aeroelectric.com/Installation_Data/
don't know if that helps you out or not.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 03-23-2010, 11:29 AM
Thanks, I have those from AeroElectric but they do not go far enough and show the actual schematic that would be in the King manual. There are several audio/in/outs + sidetones and need some clarification for my wiring project. I finished a harness to a PM501 and everything works great except audio is muted, almost non existent.
Old 03-23-2010, 02:49 PM
Got what I needed. Thanks VAF!
Old 04-13-2010, 06:29 PM
thegreg4 thegreg4 is offline
Default Pinoouts and manuals
Just email me with what you need and can help out one way or the other. I have an extensive library and can generally help out at any time with any system.
Greg@g2avionics.com
