Old 03-08-2010, 01:40 PM
jpharrell jpharrell is offline
Unhappy RV-7 Rudder Skin Oil Canning
I am seeing the rudder skin oil canning problem on the RV-7A rudder I am building. I just started riveting the skins on when I saw it so I stopped and checked the forums. I saw some posts from years ago indicating that this is not uncommon. It's in four spots on each side of my rudder. Has anybody found a good way to deal with this in the last couple of years? I spoke to Vans Builder Support this morning and they said it's not an aerodynamic issue and is inevitable to some degree but it still makes me a bit uncomfortable. I still have access to the inside of the skins and could possibly do something about it if there is a good approach.
RV-7A in Mission Viejo, CA
Old 03-08-2010, 02:49 PM
FresnoR's Avatar
FresnoR FresnoR is offline
You might want to verify that the skin stiffeners are cut short enough to provide the needed clearance from the rear spar. I accidently cut mine too long and the spar would push up against those stiffeners causing that type of effect.
Rick from Fresno
RV-7A
VAF 2016
Installing FWF
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 03-08-2010, 05:04 PM
I did check that during initial assembly of the rudder and found that one stiffener was touching one of the reinforcement plates on the spar. I trimmed it before final assembly and verified that it now has clearance. But thanks for the suggestion anyway.
Old 03-09-2010, 08:15 PM
danielhv's Avatar
danielhv danielhv is offline
can you take any pics?
Old 03-09-2010, 09:21 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Hi JP, oil canning on the rudder is pretty typical for a lot of builders. If you do a search, you'll note that a lot of guys see it on the lower half of the rudder. That's where mine is at. I wouldn't worry about it too much. Build on.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 03-11-2010, 06:01 PM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
Default Removing rudder oil canning
When I was building my 6 back in early 90's I had the same issue with the rudder having some slight oil canning after assembly. I was told thatís norm and expect to get some cracks around the rivet heads with flight time. That wasnít for me. The way I corrected it was injecting some of that yellow insulating/expanding foam you can get from the HD that gets a hard water proof outer shell. I used and tube extension to start at the bottom and work about a 1/3rd up from the trailing edge. Don't unload the whole can, experiment first with a mockup, it expands fast!!! Worked great and removed all the oil canning and with hardly no weight penalty
Thomas S.
www.g3ignition.com
Old 03-11-2010, 07:22 PM
NDrv8r's Avatar
NDrv8r NDrv8r is offline
Default rudder oil can
Thomas S.
www.g3ignition.com
Cessna used that method on some elevator trim tabs and wound up with corrosion problems. Seems moisture gets between the skin and foam. I would watch for signs of corrosion.
Larry Buller
RV7A slow build, Tip up, IO360 200hp, Catto 3 blade, Dynon Skyview, arinc 429, ems, SV transponder, Garmin GNS430w, Aera 560, Dynon D6.
FLYING!
Old 06-04-2010, 09:00 PM
skyking902001 skyking902001 is offline
Default Rudder Oil Canning
Well, I got some me of that also! I believe that it was introduced during rolling the leading edge. I had not noticed any problems up to that point. Mine is on the left side of the rudder-the side with the short skin (overlapped by the longer skin from the right side). This shows up between the 3rd and 4th stiffener from the tip rib. My stiffeners were not in contact with the rear spar, as this may also cause this problem. It appears that after rolling both sides, when squeezing the skins together, it slightly twists the spar flange inward, thus raising the skin just a tad, allowing the oil canning. I have considering using expanding foam, but I'm a bit concerned about the corrosion aspect. I don't really want build another rudder, the chance of having the same problem would still exist. Does anyone have any new thoughts on this issue? Has anyone with this problem that has flight time on their plane noticed any cracking, loose rivets etc? Thanks,
Skyking902001
RV8
emp.
Old 06-05-2010, 07:55 AM
David-aviator David-aviator is offline
Originally Posted by skyking902001 View Post
.....I don't really want build another rudder, the chance of having the same problem would still exist. Does anyone have any new thoughts on this issue? Has anyone with this problem that has flight time on their plane noticed any cracking, loose rivets etc? Thanks,
Skyking902001
RV8
emp.
I've build 3 rudders for one reason or another, they do seem to oil can just a bit.
The latest one oil cans on the lower left side and the upper right side. It is about 6 years old and has some 325 hours of flight time. There is no evidence of loose rivets or cracking skin anywhere on the rudder.
The elevators do not oil can but they do flex in and out along the stiffener lines with changing pressures. They too, do not show any sign of loose rivets or cracking skin.
Minor oil canning does not appear to be a big deal - for sure there are hundreds out there flying with it. Press on with the build!
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
I'm in, dues paid 2018 This place is worth it!
Old 06-05-2010, 07:58 AM
The chemicals in the foam may be corrosive without moisture even being present. I wouldn't use it. It's easy checking for cracks and I don't think it a big deal.
RV-12 Build Helper
RV-7A...Sold #70374
