Old 02-08-2010, 08:21 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Stand alone Workshop - cost to build?
Are there any good Rule's of Thumb to figure what it might cost to build a stand alone workshop?
I'm just trying to get a ballpark idea of what it would cost to build about 1,000 sf shop, with heat & A/C , a 1/2 bath and plenty of electrical capacity, 1 double garage door and a few windows. I figure a steel building is probably the least cost but if I do this, l might need to have a more attractive exterior (like brick).
Rick Aronow,
A&P, iRMT
Flying 7A Slider;
RV-12 (ELSA, Dual G3X), SOLD
Highland Village,TX
Old 02-08-2010, 08:35 PM
deene deene is offline
Rick, my shop is almost as you describe, with exception that it includes a small guest apartment. 10 years ago, it cost about $50K and I did all of the finish work (painting, apartment finishing, etc).
As you know, it all depends on where you are building...
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 02-08-2010, 08:41 PM
Doug Lewis's Avatar
Doug Lewis Doug Lewis is offline
Couldn't give a cost per square foot but when we built the last shop the 40x40 10'8" walls, no insulation, conventional 2 x 6 construction, floating slab painted floor full 110/220 wired, no windows, 1 door, 2 9' high insulated drive doors, standard trusses, came to $27,000 3 years ago. Got a bid for tube radiant propane heat for $1600.00 installed last week. We did nearly all the labor with help from friends.
www.kingkonghobbies.com
RV-8 Wings up next.
ƃuoɹʍ llɐ ʇno əɯɐɔ ʇɐɥʇ
Old 02-08-2010, 09:07 PM
mattsmith mattsmith is offline
Default location
It depends on were you live and if you will owner build or hire a contractor. I built a addition on my existing garage in 2005 at $30.00 a sq. ft. lights, Sheetrock, insulation, 8 foot tall two car door, engineer, architect and permits. Did all the work myself and with the help of Friends. At $30 a sq. ft. it is a Little high but in reno if you tie into existing structure you need the engineering and a full set of drawings with calcs.
Matt Smith
RV 8A
IO-360 A1A
65 Hrs
dual skiview
Reno, NV
Old 02-08-2010, 09:54 PM
9GT's Avatar
9GT 9GT is offline
I built mine 32' X 56' with 9' ceiling height. 4X6 pole construction and 2X4 stringers inside and out gave me 9 full inches of blown in insulation in the walls and 18" in the ceiling. I put in a private 1/2 bath and also a shop sink in the work area for washing up, all on a septic/well. On demand hot water. Dry walled interior, cement board siding, shingled roof, and lots of nice windows. A 9' X 16' commercial insulated roll-up door, a nice front entrance door, and a covered porch for taking breaks. Looks like a ranch style house from the outside. I got a used Lennox Pulse furnace for free to heat in the winter and even in the summer, it is so cool inside due to the insulation that I don't even need to run a fan,,,just keep it closed up. I wired 110/220 volts throughout the shop. The furnace and a 7 hp 80 gallon air compressor are in a corner utility room. I got a small refrigerator and coffee pot and can spend all day out there. NOTHING but airplane related stuff is allowed in the shop,,,,period! I did about 90% of the work myself building it and had some help from friends to assist me in the heavy framing. The only things I contracted out were the site work, cement flat work, and having the ceiling drywall hung and then all the drywall taped and finished because I hate drywall work. I built my shop 4 years ago and it cost me in the neighborhood of $46,000.
David C.
Howell, MI
RV-9A: Under Construction
"Donor Exempt" but donated through Dec. 2018
Old 02-09-2010, 05:46 AM
EFG EFG is offline
Default Airplane Factory In The North East
Just completing my personal airplane factory in the wilds of NJ (OK in the city of Linden) Basic 3 car detached garage (30 deep by 36 wide) with second floor loft over two bays. Third bay has a car lift to ceiling. Used steel beams to get a clear span. Cost w/o electrical or heat is 50K. Plus 5k for lawyers, engineer, variances, and building permits (it is in a city after all). I budgeted 65K after all is said and done with shop equipment. Looks like I might make that (yeah right)... More realistic number would be 70K.
You certainly don't need that much space to build an RV, but the other toys needed a workshop/home too. I probably should have just moved, but too late now!!!
Ed
Old 02-09-2010, 08:01 AM
zilik's Avatar
zilik zilik is offline
VAF Moderator
Default About 55K in 1996 dollars
A photo during construction in 1996. Attached to the existing house we added my shop on the ground floor and a great room, spare bedroom and bath on the upper level. Shop is 24x36 with 9 foot ceilings. I wanted 10' ceilings but ran into solid granite during excavation and did not want to blast it out.
An inside view while building the fuselage.
Gary "Seismo" Zilik
Pine Junction, Colorado
RV-6A N99PZ S/N 22993
RV-3B Tail, wings and fuselage.
Old 02-09-2010, 08:56 AM
Wayne Gillispie Wayne Gillispie is offline
Default $30,000 2006 for 24x24 1 1/2 story garage...
10' from the house, 20' from the kitchen, with 2 ton 16 seer heat pump system, 2x6 walls, 9'2" ceilings downstairs, insulated garage doors 8'x10', 100 amp service. I did most of it by myself but had some help with I beams and concrete. I do hvac for a living so that saved a bunch! Have fun.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 02-09-2010, 09:52 AM
DanH's Avatar
DanH DanH is offline
Rick, I built pretty close to your criteria a few years ago. The architecture needed to match the existing house so the whole thing is conventional stick-built with 10ft walls and a standup attic. 1050 sq feet in the main room, plus a wing for visual interest (and storing all the lawn & garden stuff). Heat pump, heavy insulation, white drywall, twelve 8ft double tube fixtures, piped air, and explosion proof exhaust fans for painting. No windows in the main room, easy cleaning, better AC performance, more wall space, and with one door the anti-theft system is a clean rifle shot from my front porch.
$35 to $40K all in. I subbed the slab, framing, drywall, siding and shingles, did the rest myself.
Dan Horton
RV-8 SS
Barrett IO-390
Old 02-09-2010, 10:25 AM
hydroguy2's Avatar
hydroguy2 hydroguy2 is offline
Default Montana pricing
I've been looking at building a hangar for a yr or so. Here's my numbers for a 50'x40' hangar building erected on my site(s).
The shell, dirt work and labor included:
Pole Barn style $8-10/ft
Steel building $12-15/ft
Concrete slab, $4/ft
Insulation, add $4/ft for Corbond type insulation, less $ for batts.
Electrical, add $1/ft for DIY. (more for contractor)
Hydroswing door $8000
Heat/AC can range wide. radiant floor with solar=big$$$ up front($5-10K), but a real saver in the long run around here. YMMV
So I can build a basic shop for <$20/ft finished ready do work, a hangar with solar heat will be another $15K. I built my 30x40 shop in 2005, for $12000 complete.
Around here, if you have the dirt, And you call a contractor. They will build you a very nice home for $150-$200/ft. A basic home with nothing fancy for $70-80/ft. and they will get you a shop/hangar type building from $30-50/ft.
It's just one Dam job after another
Brian, N155BKsold
