Old 02-06-2010, 03:11 PM
tomagin tomagin is offline
Default Requirements for IFR Certification
Now that I have started putting the 40 hours on my RV I'm starting to think about IFR certification -- ie static and txp check. I ran into someone who does IFR certs and mentioned that I will need one in the near future on my RV-8. He very quickly said that he would not certify anything that was not TSO'd --- with reference to my Dynon EFIS and or non-TSO'd "steam" altimeter. I'm confortable with what I have given that the Dynon has an ADI backup for attitude and the Falcon Altimeter for backup plus of course the 430W and 496.
The question is --- Is this guy just setting his own standard or is there any requirement that I must go out and buy a TSO'd altimeter plus a TSO'd encoder [at the moment the Dynon feeds the data to the Garmin 330 TXP].
I do not see anything in the FAR's that specify that the altimeter and encoder be TSO'd. In my case the primary box for both would be the Dynon D-180.
Tom Agin
Port Orange, FL
QB RV-8 completed!!
XIO-360-M1B with LASAR
GNS-430, GI-106A, GTX-330, 9000EX, Becker 4201, Digiflight II VSGV, ADI, Dynon Dlight Dek 180, Vertical Power VP-200
Old 02-06-2010, 04:24 PM
mayo3808 mayo3808 is offline
Default IFR Certification
He setting his on standards. Find somebody else. It is experimental.
Brent Mayo
Fernandina Beach, FL.
RV-6, RV-9, RV-9A, Onex, Panther
Dues Paid 2018
Old 02-06-2010, 04:26 PM
RV6_flyer's Avatar
If you have the transponder in the aircraft, the transponder check NEEDs to be done if you want to use it even if you are flying VFR. The check needs to be done every two years if you wish to use your transponder.
The requirement is that the equipment meet the TSO but they do not need to be TSO'ed. When he does the check, he will be verifying that they preform to the TSO. If they pass, he can certify the system. If they fail, you still need to pay for the test.
I have been using the Rocky Mountain microEncoder with my KT-76A transponder for over 12.5 years. IT has passed the certification requirements for 91.411 and 91.413 every time it has been tested since first flight in September 1997.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Building RV-8 S/N: 80012
Old 02-06-2010, 05:49 PM
Bavafa Bavafa is online now
I just had my pitot/static certification done about a month ago and they do not need to be TSO'd but the guy mentioned that almost all the non-TSO'd gauges that he has tested failed.
I have GRT for the screen and it was amazingly accurate, he tested them up to 20000 and the max that was off was 5 feet.
My TSO'd Altimeter was as much as 25 feet off at some point.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 02-06-2010, 07:08 PM
BillSchlatterer BillSchlatterer is offline
Default Are Marker Beacons required,....
Sort of related subject,.. just wondering if Marker Beacon Indicators are required to pass the IFR Cert ?
Bill S
7a finishing
Old 02-06-2010, 07:38 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Nope - not even required for IFR flight!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 02-07-2010, 08:37 AM
wizard wizard is offline
Default Find someone else
I couldn't find anyone in Boise that would sign off on my Advanced Flight Systems unit. One day when I was flying to the Portland area (and on Rob's advice), I called up Pacific Coast Avionics to see if they would do the check. I called on a Friday night and left a message that I would be in on Monday morning. When I showed up on Monday, Chris Brand fit me in his schedule and had it done by noon the next day...my scheduled departure time. Very good service...and goes to show that it's best to find someone who is familiar with the avionics that we put into our Experimentals.
Brian Hansen
Eagle, Idaho
RV-7A N6YD
Hangered at KEUL
Old 02-07-2010, 08:49 AM
svennijo svennijo is offline
No requirements for TSO'd compenents. It seems to be getting more and more previlant that shops are becoming "scared" on working on anything with an experimental sticker. I had FSDO ASI advise me that I might want to shy away from inspecting experimentals because it really opens up my liability. I think the fact is, is that some in the FAA really just don't like experimental.
But I agree, just find someone who will work with what you have installed, they are out there.
Josh Svenningsen
A&P-IA
RV-8 Slowbuild Wings: Complete
Fuselage: riveting skins
Finish kit: Just arrived!
Old 03-31-2010, 05:28 AM
Gregmarlow's Avatar
Gregmarlow Gregmarlow is offline
Default How can we find someone?
How do you find someone that will do this? Anyone know of someplace reasonable in the southeast?
Greg Marlow
RV-9A Flying
East Tennessee/SW Virginia
Old 03-31-2010, 05:34 AM
pierre smith's Avatar
Default Hi Greg....
...I have used Abbas Avionics when they were located in Augusta, Ga. for transponder checks and encoder adjustment. I understand that they've opened up a big, new facility in Aiken, S.C. Maybe some of the KCUB EAA chapter will verify this...or you can call information for their phone #
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15
Air Tractor 402 PT-6-20
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
