Grant Stewart
I'm New Here
One of the things I've seen with trailers (boats and caravans) is it bouncing all over the road while the vehicle pulling it, is gliding along. After some investigation with trailer manufacturers, who deem 1400lb "light weight"; leaf springs are worse for this bounce than the rubber "springs" used for little squre box trailers. Both are pretty bouncy. Air suspension is king for a smooth ride.
The advantage of air suspension is that it can be lowered or raised, and gives an exceptionally smooth ride, typically used in the luxury end cars range rovers, mercs, rollers etc. Air suspension kits are sold typically to modify cars, low riders for example, that can be pumped up to legal heights if required.
If you could lower the suspension of the trailer, then the angle of the aircraft loading could be reduced, reducing chances of tail strikes, less force to pull/push it onto the trailer and most importantly a smoother ride giving the instruments/component/nuts and bolts inside the RV less stress, rattle and roll.
My plan is to keep the 12 at home, so I need to know it is going to work in real life.
There are some interesting threads on design shapes and sizes however has anyone considered air suspension?
