danweseman
Hi All Im Working on a old-4 kit (#717) im preparing to final rivet the Skins on the fuse. I need info about the "engine mount" weldments. The ones installed both upper and lower are both .071 thick with the corners welded . The lower ones also have a large (5inches H x 5 inches L) 0.125 Al triangle gusset riveted in the side of the steel bracket and into the vertical aluminum angle firewall stiffener. By the info i can find these seem to be the heavy one? But the new set of plans i bought a few months ago(to be sure to build it with the latest updates) Show the lower brakets being .125 thick ? Ive have never seen ones .125 thick in all the -4s ive looked over including several built at my airpark? Dose any one have a set of the latest ones form Vans , if so are they .125 thick? Also the foward side skin is .040 ? Thanks for any info or advice Dan Weseman
