Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 12-02-2009, 07:42 AM
RV9er's Avatar
RV9er RV9er is offline
Thumbs up Tip: Rib Flange Straightener Tool
Here is my version of a tool made by Bill Gast of Boone Iowa (Gotta give credit to the man who invented it) This REALLY makes the tiresome task of streightining rib flanges go fast, accurate and easy. Mine is made of some old Oak I had on hand, some flat bar from the local ACE hdwar store, a few screws and 2 AN Bolts from the used box . The angle between the anvil and the sqeezer is 11 degrees on the face and 11 degrees on the bottom of the sqeezer.
Old 12-02-2009, 09:02 AM
larrynew's Avatar
larrynew larrynew is offline
Good design. I'm using one very similiar and it works well. My first attempt used 14 degrees as recommended on another website. I found 11 degrees works best for me.
Larry New
RV-7A - Flying 800+ hrs
48 States in 7 Days!
RV-10 - On schedule to fly summer/fall 2020
VAF Paid - Annual Autodraft
Old 12-02-2009, 09:06 AM
mototopo's Avatar
mototopo mototopo is offline
Why do you come out with this !#@!! tool just after I completed my last rib?!??!?!?!?
Claudio
Was Avellino - Italy...
Now Cypress, TX
www.rv7a.it
RV-7 I-KLAU (Reserved)
Empennage Done!! (except fiberglass)
Wings done!!
Working on aft fuse.
...SOLD!
Old 12-02-2009, 10:13 AM
rv8eh rv8eh is offline
Default Electrical tape is your friend
I built one of these out of scraps, and here are my lessons learned:
It matters where you pull on the lever, and how hard.
I marked the sweet spot with a strip of electrical tape.
I was getting occasional scratching of the rib from the tip of the lever (the business end) so ran a strip of electrical tape across it, and replaced it when it fell off or wore - 2x I think.
I used an imperfect piece of plywood for the baseplate, surface wasn't perfectly flat, and ribs would stick slightly as corners caught on the plywood's rough surface.
Yup, a strip of electrical tape a few inches either side of the anvil on the base plate, and no longer a problem. Replaced it occasionally.
I used the angle from the 21 years of the rvator article - it was nice to see the legible picture in the 24 years of the rvator version.
This tool didn't take long to make, and really sped up straightening the ribs.
Howard McKay VAF 573
RV-8A, empennage/wings
Old 12-02-2009, 10:51 AM
Jim P's Avatar
Jim P Jim P is offline
Claudio, ummm, actually, the flange straightener has been around for years and is detailed in the 21 (or 2x) Years of the RVator book. However, the drawings aren't very clear. For folks just starting the rib straightening, it's well worth the time to build the tool!
Jim Piavis
RV-7 (Flying!)
http://adap.com/rv7
Redmond, WA
Old 12-02-2009, 12:32 PM
RV9er's Avatar
Talking Next RV
Just use it on the second RV that you build.
Old 11-11-2011, 09:34 PM
mculver's Avatar
mculver mculver is offline
Resurecting an old thread for others who may not have discovered it. This is excellent idea, so built my own variation of the tool -- see http://www.mculver.com/2011/11/nov-9...ightening.html
-- Mike Culver;
RV-9 project sold but details of the build at
www.mculver.com
Old 04-02-2012, 05:49 PM
SilverEagle2's Avatar
SilverEagle2 SilverEagle2 is offline
Like Mike, I think it is a good idea for us to occasionally resurrect valuable threads.
I just completed my version of this tool and tested it. Thanks to Bill and others, for the ideas and design pictures.
Now, I just need to get the Empennage out of the way and get started on using it.
Jason Hess
N777JH - Reserved
RV-7 - Builders Log Tail complete, wings nearly done, starting fuselage!
RV Factory - Complete sans floor coating, Slideshow Here
People are not excellent because they achieve great things; they achieve great things because they choose to be excellent.
Gerald G. Probst, Beloved Grandfather, WWII B-24 Pilot, Successful Businessman
Old 04-02-2012, 06:01 PM
Default HS ribs
This looks like a pretty good idea and way to straighten out the ribs if they are bent. Im just on the empannage kit, but I didn't have much of an issue with bent ribs. The one's that were slightly out, I just used the hand pliers with a 2" mini brake I got at HF. I thought it went pretty quick. I can see how this would do a more accurate job than a hand brake - much more important on the larger wing ribs. If I don't do the QB on the wings, Im going to build one of these.
Thanks for bringing it up again. These little tips really help.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 12-09-2012, 07:45 PM
wjb's Avatar
wjb wjb is offline
After reading this excellent thread, I built my own version (with happy rib inserted)
It works great, though I learned a few things...
For one, you gotta pull pretty hard to straighten the 0.032 ribs; no issue with the 0.025 ribs. Don't be shy building this rig to be strong. The handle should be made out of a dense hardwood; I used 1" square maple here (that's what the aviation department of my local ACE had in stock). The handle is 18" long ... probably about right; 24" would be good too. I got best results clamping the plywood base to the bench so the rig wouldn't move. A 2x4 scrap seems to work fine for the anvil base.
Thanks VAF for the good advice!
Bill Bencze
N430WB RV-7 #74152, tip-up; IO-360; CS. Pushing toward first flight in 2020!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2020 donation happily made
