31-06 reed switch
I thought that the suggestion by JohnF to magnetize the WD-1217 tube was ingenious. Jerry G, you could have magnetized the WD-1217 with the wrong magnetic polarity, which would hinder instead of help. If I am reasoning correctly, the top of WD-1217 tube should have the same magnetic polarity as the WD-1217C Fuselage Pin Stopper magnet. The polarity of the tube and the magnet can be determined by separating them and then testing each with a compass. When magnetizing an object such as the WD-1217 tube, the polarity is affected not only by the polarity of the stroking magnet, but also by the direction of the strokes. All strokes should be in the same direction. After ending a stroke, the magnet should be held away from the WD-1217 tube while returning to the starting end for the next stroke. The WD-1217 tube could lose its magnetism over time.
Another idea that I had, but never tried, is to cut a 1/2" x 1/2" piece of galvanized steel or tin can lid. Place the small square of steel on top of the F-1248B to help bridge the gap between the magnet and the reed switch. If it works, the steel could be epoxied in place. Jerry, I know that you have spent too much time on the reed switches already, but cutting a small square of steel will not take long.
Let us know if you get it working and what you did.
Joe
