Closed Thread
Old 10-06-2009, 12:53 PM
erich weaver's Avatar
erich weaver erich weaver is offline
Default MOA/Restricted Area Communications
OK, bonehead questions here:
(1)If one is on VFR flight following and the flight path will take you over an MOA, what type of interaction should be expected with the controller as the MOA is approached?
(2) Same question as above for a restricted area
thanks
erich
Old 10-06-2009, 01:02 PM
MNForrest MNForrest is offline
Default Not much
Unless the controller needs to route you around or make you aware of traffic, not much. I had flight following from MSP crossing the MOA's near OSH this summer. Not a word from the controllers, but the MOA's were inactive.
www.flyexperimental.net
Old 10-06-2009, 01:12 PM
I usually ask the question "is the area hot", you never know if the controller is busy with something else, and might miss your entry into the area.
If he/she gives the OK, well, then it is on tape.
Old 10-06-2009, 01:17 PM
7pilot's Avatar
7pilot 7pilot is offline
Default Maintain VFR
This is the standard response by the controller when you request flight following and it means you are responsible for your own separation, they will advise you as they can depending on their workload. They are not providing you a clearance so you are not cleared into a restricted area unless you ask specifically and receive a clearance. The best thing you can do is talk to the controller about the MOA, if he can't tell you if it is active then he will be able to tell you who can. However, just because the MOA is active doesn't mean you can't be there - use your own judgement, I often travel through them but always contact the controlling authority and find out if it is active and if I enter I stay out of their way and still ask for flight following. Often the controller will let you know where the aircraft are at and be able to give you some guidance. (i.e. A-10's operating between 10 and 12 and will be staying South of ...) I rarely if ever ask for clearance through a restricted area. Some are not operational all the time though, so you can get clearances through them on a case by case basis.
Stewart
Stewart Cole
N156DE RV-7A Tip-up, IO360 CS MT Prop
http://www.7pilot.com
Old 10-06-2009, 01:30 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Default MOA / Restricted Airspace
Stewart
Stewart's reply is spot-on, and I would like to add that I always ask for clearance through restricted areas (especially since I'm surrounded by MOAs and Restricted airspace here near Edwards AFB-SoCAL). No harm in asking
On long cross country trips, I'll ask the current controller long before I get to a MOA / Restricted Airspace if the airspace is 'hot' so I can deviate sooner rather than later. If the controller is busy, I'll jump is with a quick "Is 2515 'hot'?" which always gets a quick reply.
Lastly, be sure to check the MOA altitude block as you will find the floor of the MOA may be above your current altitude Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 10-06-2009, 01:32 PM
Toobuilder's Avatar
Since my home airport is within a MOA, I don't pay very much attention to them anymore. I still look for traffic, just as always, and the occasional sight of a flight of F-16's has the same element of caution as a flock of birds, or students in 172's... I don't want to hit any of them. So short answer: no clearance required for a MOA, hot or cold. But it is a fine idea to ask someone what is to be expected, just for peace of mind.
Restricted areas are another matter altogether. If on flight following, they will need to give you specific clearance to enter, if at all, and that clearance is often accompanied with a minimum altitude restriction. That said, I have been advised to remain clear, cleared above 6,000, or cleared straight through the Edwards AFB complex... It all depends on what is going on that day.
Michael Robinson
______________
RV-8 - Flying
Old 10-06-2009, 01:37 PM
pierre smith's Avatar
Default I live smack dab in the middle of one...
....and Atlanta won't give flight following if the MOA is hot. All of my spray work is in this one and I just go about my business every day and keep my eyes open, with their floor at 500'.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor AT 502B PT 6-15
Air Tractor 402 PT-6-20
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-06-2009, 01:38 PM
the_other_dougreeves the_other_dougreeves is offline
Ask the appropriate Center controller unless there is a controlling agency listed for the MOA and/or Rstricted area. These will be published in the margin of the sectional.
As others have said, it's optional for MOAs, but required for Restricted areas.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 10-07-2009, 09:59 AM
ColmOReilly's Avatar
ColmOReilly ColmOReilly is offline
Default See And Avoid
I've also found this site useful to see the various sections of airspace and their current status.
http://www.seeandavoid.org/
Colm
Old 10-07-2009, 12:09 PM
N8RV's Avatar
N8RV N8RV is offline
Default Seriously?
I have 2 MOAs smack in the middle of my Phase I test area. Because of some weird radio issues that I'm troubleshooting, I've not been successful in determining whether the areas are hot or not. So, I usually just turn around and head back.
You mean that I can fly through a hot MOA without talking to anyone if I want to? I can fly right through it legally?
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Closed Thread
