Since I really want this solved
I thought I would post what I think is other relevant data:
1) I have blisters on the top of my tanks only, and entire rivet lines not just a few random rivets.
2) My tanks were slow built and leak tested with air, no leaks for 3 days. All shop heads of the rivets and rib/skin seams are sealed with proseal (ie, I probably OVER did it).
3) I flew my plane over a year or 150 hours before paint.
4) The tanks were completed in a HOT hangar in Texas about 3 years before painting.
5) I used the pro seal from Van's
6) I used the special tank dimple dies available from Cleaveland that dimples the holes a little deeper to account for the proseal
7) My painter sanded and filled all rivets on the top of the plane to give it a composite look (see pic below)
8) paint on the tanks is Jet-Glo Matterhorn white, clear coat on top of that. Unsure about primer.
9) It took about 8 months (and a HOT summer) post painting for the first blisters to show up
10) I have never had any leaking from the fuel tanks top or bottom, nor any liquid at all after popping at least 20 of the blisters.
11) I am uncertain about what solvent was used to clean the surface or the type of paint thinner used in the paint
