Space Cadet
Unfortunately, my mid-time IO-540 engine was not pickled for long-term storage after a top OH and test run, and is now going to sit in a crate in my garage for a while (6 months or more possibly).
Although it is pretty dry here in Denver, still concerned about rust over the long term. Have access to cylinders through the spark plug holes, and they are nickel-treated anyhow so won't rust. But for the lower section? Dropping the oil sump seemed to be a relatively simple answer, but looking at Lycoming manuals it does not appear there is much, if any, real access to the drive train (crank, cam, etc.) through the sump area.
Can someone confirm if I would have enough access to spray some fogging preservative oil up through the bottom- at least good enough to make it worth it? If not, other ideas? Just seal it up and use lots of dessicant?
Thanks!
Dwight
Thanks!
Dwight
