Old 09-20-2009, 09:48 PM
llavalle's Avatar
llavalle llavalle is offline
Default EAA Work tables
I was just sick of my old work table with folding legs. I decided it was time to change. I was also probably looking for a reason for not working on the tanks
I was about to create my own design when I found out about the EAA 1000 tables. They looked sturdy and easy enough to build.
A small trip to "Home Depot Aircraft supply" to pick up lumber, carpenter glue and screws. After a couple of hours, this came out of the shop :
There not made of shiny aluminum but I think they look nice!
The sanded plywood was not good enough for my taste, I went with a 3/4" maple veneer plywood . I used left over from the wing crate (pine board) to create the moulding using a router.
Used a nice gel stain for the finish of the top plywood. I'll add sealer tomorrow to make it more resistant! I'll also need to level them. They are straight but my garage's floor isn't.
Total cost of the project : $130 (Canadian dollars) ~$120 US This includes lumber, screws (almost 300), glue, stain and taxes (around 13% around here).
Total time to build : 4-5h. I had the help of one of my buddy who works as a carpenter. Having the right tools and the knowledge helped a lot!
Philippe Marseille
RV-9A Emp complete & Inspected, @Wings - First tank Sealed!
Construction Web Cam
Old 09-20-2009, 10:14 PM
hydroguy2's Avatar
hydroguy2 hydroguy2 is offline
I like the EAA tables. I built mine larger, and used a full sheet of 3/4 MDF for the top. MDF is smooth and flat. I consider the surface to be sacrificial, so I drill and cleco right to it. Also no router edge for better clamping.
It's just one Dam job after another
Brian, N155BK
SARL #155
Old 09-20-2009, 10:33 PM
mdredmond mdredmond is offline
I made mine longer (7') and put a sheet of 1/2" MDF on top of the 3/4" plywood. It is screwed to the plywood from below and 'captured' by hardwood trim on the outside edges. I can replace the entire top of my bench by removing a few screws and cutting a new piece of MDF.
Matt Redmond
Denton, TX (KDTO) - VAF #510
Got the Bug & Wife's Signoff
RV-9 Tip-Up, Empennage & Wing
Old 09-20-2009, 11:12 PM
aarvig's Avatar
aarvig aarvig is offline
Default Nice tables!!
Nice looking tables. What size did you make them and where did you get the plans?
Aaron Arvig, DC
Oneka Chiropractic, PA
http://www.onekachiropractic.com
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
Old 09-20-2009, 11:23 PM
Texinvegas Texinvegas is offline
Default EAA 1000
Google "EAA Chapter 1000 workbench". That will take you right to it. I have built two of these myself. Really happy with them.
Kristofer White
San Angelo, TX.
RV-8 Builder # 82628
"Free people sleep peacefully in their beds at night because rough men stand ready to visit violence on those who would do them harm." -George Orwell
CraigC CraigC is offline
They are at the EAA Chapter 1000 website. Here is the link.
http://www.eaa1000.av.org/technicl/w...l/worktabl.htm
Craig C A&P/IA
Mesa, AZ RV-8 SerNo 82582
Wings/Fuse N18VA Res
Old 09-20-2009, 11:53 PM
AX-O's Avatar
AX-O AX-O is offline
You should put wheels on it. It makes life so much easier.
http://www.mykitlog.com/users/displa...g=13778&row=14
http://www.mykitlog.com/users/displa...g=13777&row=13
Axel
Southern California
RV-4 fastback: http://www.vansairforce.com/communit...ad.php?t=39772
RV-4 fastback Pics: http://picasaweb.google.com/N704TK
West Coast Ravens: http://rvformation.com/westcoastravens/
VAF 2013 paid VAF 704
Old 09-21-2009, 07:03 AM
RV-7A N614EF
I also typed some up here and added a few links.
Bob Collins
St. Paul, MN.
N614EF RV-7A
Flying - Just like a real builder
Blog: Letters from Flyover Country
Twitter: http://twitter.com/N614EF
Facebook: RV Building
Old 09-21-2009, 07:19 AM
Crossbow Crossbow is offline
I probably over-did my main table, but I am glad that I made it four feet wide and twelve feet long using 2X6 and a 3/4" MDF top. It is very flat, level, and allows for plenty of work area.
Old 09-21-2009, 08:03 AM
techbill techbill is offline
Just got my first one built. Plans does seem to waste a lot of plywood though. Or enough left over to build a third bench.
