Here is my statement to the FAA, including revisions from last night. I
bought the salvage back from the insurance, so I'll be rebuilding for quite
awhile.
Statement of Richard Zeidman, Pilot of RV6A N42RZ on May 11, 2005
On May 10, I flew with a passenger to Sussex County Airport (GED) and on the return flight, I stopped for fuel at Ridgely Airpark (RJD) for about 5-10
minutes. Upon engine restart no fuel pressure was noted. I suspected a vapor
lock and after 15 minutes the fuel pressure returned and an uneventful
flight home to New Garden followed. The next day, I returned to check the
problem. No discrepancies were visible on the fuel pump externally, but I
added a blast tube to help keep the engine fuel pump cool. A short solo test
flight was performed to check problem. The electric aux pump was on
throughout most of the flight. After takeoff, I climbed to 3000 ft and
headed west about 10 miles.
I then turned east and did slow flight for several minutes and a full power
off stall. I was over New Garden airport when I finished and decided to head
east toward my home. I was descending at 2000ft at 160 kts about 2-3 minutes later , I think I tested the aux pump switch and then when I noticed a power loss. I immediately tuned 180 toward New Garden and switched tanks from r to l and went full rich and checked my aux pump was on. Power loss continued and I noted RPM was now 900. I realized I was not going to be able to reach New Garden so I switched to 121.5 and called mayday and headed for a nearby field. After touching down normally with full flaps, the plane rolled several hundred feet and bounced. After the bounce the nose gear dug in and the plane flipped on it?s back. Upon releasing my harness I realized I was trapped and as soon as help arrived, I asked them to remove some of the broken plexiglass and I was able to slide out.
I confirmed now that the electric boost pump was malfunctioning, causing the
both night?s problem.
I disconnected the fuel line to the carb and the electric pump worked fine.
I reconnected it and initially it worked ok, 5psi, for about 5 minutes. It
changed tempo slightly after that. I then turned it off and back on and it
started buzzing and would not pump at all. I cracked the line to the carb
and the pressure dropped to zero. It is not allowing fuel to pass, so the
engine pump cannot work. I repeated the test again later.
