Jeff R
I am running #4 AWG wire to the alternator. The terminals for #4 cable (and even #6) are sized for an AN5 bolt. The 60 Amp Plane Power alternators, however, have a 6 mm stud (about .236"). Even a terminal for a #8 wire is a tad oversized, so the #4 terminal is way big for the alternator stud.
How did you guys handle this? Do you just trim off some of the wire strands at the end so the cable will fit into a #8 terminal?
Thanks.
Thanks.
