MartySantic
Received my CARE package today and installed the magnet in the wing pin (not yet expoxied) and the reed switch wired to a DVM. Could not get the reed switch to close after trying a multitude of reed switch positions.
In the fuselage the magnet is vertical and the reed switch is horizontal and is 9/16" from the tip of the reed switch to the magnet centerline.
Removed them and did some bench testing. With the magnet vertical and the reed switch horizontal you have to get them to within 7/16" for the reed switch to work (close) reliably. The pair become more sensitive if you could mount the reed switch vertically. With the magnet AND reed switch vertical, (ie. side by side) they work reliably at 9/16".
Also tried reversing the magnet, did NOT make a difference. Also tried mounting the magnet higher in the tube, it was worse. The reed switch is more sensitive to the magnet ends as opposed to the center of the magnet (with the magnet vertical/reed switch horizontal).
This is MOST definitely a problem and will e-mail Vans.
ANYONE have any better luck??
