I recently read a forum comment from someone who had a lot of trouble with nutplates, and actually broke off a screw in one because it was so tight. My experience so far with the empennage and wing kits has taught me a couple of lessons that I will share in hopes of saving someone else a lot of grief.
Because they are so tight, and invite screw head stripping and worse, I have adopted the practice of testing all nutplates before installation. I put them in my vise (before countersinking the mounting holes) and manually drive the matching screw or bolt into the nutplate, using a bit of the Boelube dry lubricant on the threads. This gets the first insertion out of the way in a controlled environment before installation in the airframe, making subsequent insertions easier, and also will identify any defective unit or buggered up threads.
Sure is a lot easier doing this on the bench, instead of in some hard to reach place on the assembly.
