I've finished dry fitting the baffles around my ECI IO-360 (RV-7A) with cold air induction and have begun fitting the fiberglass snorkel. I was not surprised by the significant modifications that it appears will have to made to the snorkel in order to fit around the alternator and starter based on earlier posts. After all, at this point what is a bit more fiberglass misery.
What has surprised me and left me a bit vexed is the extremely tight fit where the snorkel attaches to the left front inlet ramp. At this point I have two issues, first, I just don't seem to have enough room to cut the hole for the filter and still have a reasonable amount of edge margin to attach the top plates that secure the filter in place, let alone a nice gap for the seal material between the cowling and inlet ramp.
The second issue is the diagonal bend across the inlet ramp. Per the instructions, I put in a slight bend diagonally across the ramp so that it matches with the lower lip of the cowling, which it does nicely. But now the filter has to bend slightly to fit since the cut-out goes across the bend. I can do this, but when I called Vans they said there is no bend and the filter should lie flat. Have I missed something in the instructions or has anybody else faced this "challenge". Any insight would be greatly appreciated.
