Old 04-01-2009, 07:11 PM
TomVal's Avatar
TomVal TomVal is offline
Default Compass Correction Card
Is a compass correction card required if you have a whiskey compass installed? I notice many panels do not have the correction card installed.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 04-02-2009, 07:05 AM
Mel's Avatar
Mel Mel is offline
Default Yes!
If you have an adjustable whiskey compass, the correction card is required.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 04-02-2009, 03:37 PM
TomVal's Avatar
Default Correction Card
Thanks...that's what I thought.
Regards
Tom Valenzia
RV8 (Sold)
Old 04-02-2009, 03:52 PM
frankh's Avatar
frankh frankh is offline
Default Whats a compass?
I saw one once in a C152 I think...
Old 04-02-2009, 04:08 PM
Mel's Avatar
Mel Mel is offline
My 1941 T-Craft had one.
North Texas (8TA5)
FRIEND of the RV-1
Eagle's Nest Mentor
Old 04-02-2009, 04:26 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Mel congratulated me on a "complete panel" when he did my airworthiness inspection because I actually HAD a Correction card. It wasn't filled out, as I hadn't swung the compass, but he said that wasn't necessary - having the card and holder gave me a gold star!
Hey Mel - I actually filled the card out - about a year later....when I had nothing better to do....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-02-2009, 05:19 PM
zzapp zzapp is offline
Default Does it matter?
I rebuilt my compass and swung it. Spot on east-west, 1 degree deviation north -south. Let's be honest here. Who can hold a heading in one of these things plus or minus 1 degree? Do I still need the card? Yea, I know the answer, It's a hypothetical question.
Old 04-02-2009, 05:48 PM
Jeff Brenhaug's Avatar
Jeff Brenhaug Jeff Brenhaug is offline
Easy to make in Excel and print on a sticky.
Pic attached.
Old 04-03-2009, 01:14 AM
az_gila's Avatar
az_gila az_gila is offline
Question OK Mel...
...which FAR actually requires the card?
I can't find one, even for my certified 77 Tiger.... It doesn't even appear as a required placard in my Maintenance Manual.
The FARs require the compass, but even the TSO for a compass (TSO-C7c)does not call out for a correction card. We have other instruments that have errors, and no correction card on the panel.
NOTE - I am not advocating no card, but with all of the ramp/DAR inspection talk, I can't find the regulatory requirement. Perhaps it's been around for so long, they just forgot to write it in...
NOTE 2 - I just found it for my Tiger, it's buried in the certification requirements of FAR Part 23 (23.1327 and 23.1547)
But part 23 requirements don't apply to Experimental Aircraft, do they?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-03-2009, 01:46 AM
Pirkka Pirkka is offline
Default Compass correlation card in EFIS?
As this correction card is not needed much anyway but recommended or required here at least, does any EFISes support to write down information there? Ok, next you are going to say that I'll need compass when EFIS is not functioning anymore -- I agree, but correlation of couple degrees is most probably my least concern at that moment.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
