Did I just screw up my carb by trying to add my carb temp sensor?
ArVeeNiner
Well, I may have made another expensive mistake. I had a lead plug in the spot on my carb that accepts the carb temp sensor which I got with my Dynon. Following the directions, I carefully drilled out the lead plug without enlarging the hole. So far, so good. The directions said to tap the hole to 1/4-28. I tried but it wasn't taking the threads because the hole was too small. So, I drilled the hole out to 1/4". I think this is where I made my mistake. Then I tapped it to 1/4-28. You know where I'm going with this. Now the hole is too large for the sensor. What do I do now?
Do I try to figure out a way to plug the hole back up and forget the sensor? Can I bond in the sensor? Do I add a Heli Coil? I hope I didn't make a huge mistake!!
My inclination would be to first find out what the correct size/pitch is, then try to find a helicoil that may work and see what the size/pitch of the tap is for it. If it's too close to 1/4 to make it work nicely, I'd find a 1/4-28 plug, screw and stake it in, and leave the carb inlet temp to those who really need it (cessnas).
Kelly
You have indeed drilled the hole out to the wrong size. The correct size is always smaller because you have to allow for the thread depth.
It seems you now have two options:
1) Get a helicoil fitted
2) Drill and tap it for a larger plug.
Personally I'd take it to someone and get the helicoil fitted. Then you can still have you temp gauge. As someone who's experienced carb icing before I think it's a good idea to have the gauge.
Peter
Rethread with Time-Sert
I used to own an auto repair and machine shop, and found the best thread repair system to be the ones manufactured by Time-Sert. These have a flange at the top, are solid sleeves, and install flush in a counterbored groove that is cut in the part with a tool that is supplied in the installation kit. I have installed thousands of these. most high mile Cadillac Northstars have the cylinder head bolts retained in the block with this system. I have installed them in several positions in Lycoming case halves in the past. They are air and fluid tight, totally structural, absolutely permanent, and there is no way the threaded repair can unwind from the back and end up in the venturi and get swallowed by your engine. The kits are very expensive, and the inserts can run about 3 bucks each, so it is probably best to contact your local well equipped automotive machine shop and have one installed. I would expect this to be a 30 buck repair. Yes, a Helicoil will work, but if you want the very best repair that is airtight and secure, this is the way to do it.
Hope this helps,
Chris
Well, I may have made another expensive mistake. I had a lead plug in the spot on my carb that accepts the carb temp sensor which I got with my Dynon. snipped So, I drilled the hole out to 1/4". I think this is where I made my mistake. Then I tapped it to 1/4-28. You know where I'm going with this. Now the hole is too large for the sensor. What do I do now?
snipped
Kelly,
The correct size to drill for a 1/4"-28 tpi (NF) is a #3. For 1/4"-20 tpi (NC) is a #7. You can find a tap drill guide here. See
http://www.newmantools.com/tapdrill.htm
Chris' suggestion above sounds like the best solution to me. Second choice is to install a HeliCoil. I don't know if there is enough "meat" around the hole to install a Time-Sert. If you have never installed HeliCoils or Time-Serts, your new carb is NOT the place to learn. In that case, take it to someone with experience doing this. A machinist would be my first choice.
Charlie Kuss
Chris
That's exactly what I was worried about. I'll check around and have an expert do it.
I would guess that I don't want the repair to protrude beyond the carb wall on the inside downstream from the butterfly right?
Lesson learned: If you feel a bit rushed, just stop and come back tomorrow. I was aware at sometime in the past that you had to drill a hole a bit smaller than what you're tapping but that information flew right out of my brain. I hadn't worked on the project too much this week and I wanted to get a quick job done last night. Now it's a bit longer job but fortunatly, not something that cannot be fixed.
Thanks for all the help.
Timesert
As suggested, a 1/4-28 timesert is the way to go. These are the "good stuff".
http://www.timesert.com/
For those that are not familiar with this product, it is a particular type of solid thread insert. It is much thinner wall than a Jergens, Carr Lane or Eze-Lock because the Timesert uses a custom outside thread design that "nests" with the desired internal thread. Most compact solid insert repair possible.
Per Charlies comment, there may be limited meat for a standard Eze-lock type, but there is gobs of room for a Timesert. The second advantage is the top flange for the reasons that Chris mentioned.
I don't find these to be common knowledge. Make SURE the machinist knows what you want.
I will add my aye vote for the time sert, but I suggest a couple of things when using it.
1. Machine a spot face on the casting----this is a smooth area for the time sert flange to sit on. A decent machinist will know what to do.
2. Use a sealant to prevent leaks. Locktite 567 should do well.
Good luck.
Larger probe?
I would first check and see if there is a temperature probe with a 5/16 or 3/8 thread. Dynon and JPI would be a good source. These are fairly simple probes and hopefully there will be different sizes available. You can then drill and tap for the larger size and avoid having to use a thread insert, which gives you two possible leakage paths instead of the one. In any event, make sure you determine the correct drill size for the tap. The metal on the carb is also very soft, so if you are unfamiliar with tapping a hole, it would be a good idea to first take a piece of 1/4" aluminum (any, not necessarily your good airplane stuff) and practice drilling and tapping, using a bolt to check your fit. Getting a cohort who is familiar to give some advice might be a good idea also. Bottom line is you want to dry run your technique before possibly buggering up your carb:eek:.
I know this is probably a bitter pill to swallow, but this is a learning experience!
Ordered the TimeSert kit
I have a friend who is very familiar with installing inserts. He's done many more than I have. I talked to TimeSert which was very helpful. He walked me through the entire process. The kit was $60 + shipping and it includes everything, including the correct drill bit this time :), the counter bore, tap, installation tool, and inserts. I consider the $60 my penalty for rushing through something and making a bone head mistake. Shame on me. UGH! :mad:
Timesert also suggested threadlocker so I'll do that plus, after the sensor is installed, I'll throw some RTV around it.
A bigger diameter sensor did cross my mind last night but I decided that I'd try the fix first which looks pretty straight forward.
I kicked around the Helicoil fix for a while but the vision of the Helicoil working loose (unlikely) and getting sucked up the carb (even more unlikely) was imprinted in my brain. I like the piece of mind that the Timesert cannot work itself out towards the carb throat.
I thought I recognized the Timesert name. I'm lucky enough to have a Ford Triton engine in my truck and I remember researching how I'm going to fix the spark plug threads WHEN (not if) a spark plug blows out of a hole. Timesert has specific kits for this repair. I will have some experience under my belt when this occurs!!
And once again, thank you for all the great information!! If this kind of support network didn't exist I doubt I would have even started this project.
Time Sert
Couple more points on the Time Sert. Mike suggested spot facing the area, but that is not required, as the tooling supplied will face the groove for the flange using the resized bore as the center. Even marginally rough or uneven castings lend themselves well to the process. Spot facing would be required for clearance of the cutter in some applications, but I doubt it will be required here. Also, Mike is right about the loctite. That is standard procedure for installation. The Time Sert installation also is resized at the final step to lock the sleeve in the casting. That is not possible with a Helicoil. As for length, many options are available. It's not an issue here, as you have access to the rear of the bore to trim off the excess carefully with a die grinder. This all sounds like a big deal, but once you learn the process, the whole deal takes about 5 mins.
As others have stated, it's tricky to learn the process, so I wouldn't make my carb the first project.
Best of luck,
Chris
Best of luck,
Chris
Chris, how right you are.
I made the suggestion prior to reading the timesert info, neat device I must say.
I will use these in the future if I ever need to replace a thread, that is for sure.
Time Sert Believer!
So I ordered my Time Sert kit on Thursday and it arrived here yesterday! I first practiced on a piece of scrap aluminum then did the real deal. It was amazingly easy and quick. Another crisis averted!! The results are below.
I wonder if I can sell what remains of my Time Sert kit to recoup some of the cost. Time Serts aren't cheap but faced with a trashed carb, well worth the price.
Thanks for all the help!!
Nice, neat looking repair. I'm sure someone will be using this info to fix oppses down the road.
