Paul the Overlord
Hi,
I have finished beating the longerons into submission (I think). Is there a way to test fit the 95.4 angle with the twist (the curve is easier to test fit, so that should be ok I think)? I'd rather not rivet the side skins on until I'm sure that the opening of the angle and the twist will fit whatever they are fitting against. I thought I could cleco the remaining parts together if that will help. Thanks!!
