Addicted to the site?
Donate yearly (please).
Advertise in here!
Today's Posts | Insert Pics
Old 03-13-2009, 09:38 PM
pilot28906 pilot28906 is offline
Default Countersink size for #6 screw?
I have found the max-min countersink diameter for a #8 screw but can not find the max-min diameter for the #6 screw. I am countersinking the wing spar for the access plates and this info would be appreciated. I am affraid that using a dimpled sample piece will make the countersink to deep.
thanks,
John
John Johnson
Murphy, NC
RV7(A)
Old 03-13-2009, 10:22 PM
TerryWighs TerryWighs is offline
Send a message via Yahoo to TerryWighs
My chart says a number 27 dimple die.
RV-8 builder...Reindeer Man
Salina, Kansas
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage (50% done...
Old 03-13-2009, 10:45 PM
az_gila's Avatar
az_gila az_gila is offline
Smile It looks like..
thanks,
John
..0.257 to 0.279 inches will do the job nicely
The screw specification is here....
http://www.av8design.com/Hardware/MS24693.pdf
Gil Alexander
RV-6A VSB (Very Slow Build)
Grumman Tiger N12GA - flying
Old 03-14-2009, 08:30 AM
Sorry John......Misread your question. Was thinking access plate, instead of the spar which is countersunk...
Salina, Kansas
empennage done
Wings done
Old 03-14-2009, 01:59 PM
mcencula mcencula is offline
Default Use a sample
Hi John,
I believe that if you use the recommended size for the screw head you will not be happy with the results because the access plate will not sit flush. I used a sample plate for all of the countersunk locations in my spar including the rivet locations, tank attach screws, and access plates. In all cases, the countersink is slightly (~.005 for rivets, ~.010 for #8 screws) deeper for the mating skin than if only the rivet head or screw head was fitting in.
Good luck!
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
Old 03-14-2009, 05:58 PM
JoeLofton JoeLofton is offline
Default Spar Countersink Dimensions - Tank and Access Panel
The RVator first issue 2005, "In The Shop" section, gives the Van's recommended technique and dimensions for the tank attach countersinks in those beautiful golden spars. These are the outside diameter dimensions:
Tank attach - 0.365” to 0.375” diameter (from the article)
Access plate attach - less than 0.3125" diameter (from later discussion of the topic on the forums)
The technique was to cut the head off a screw to use as a gauge, countersink until the screw head fit flush to the spar, then go two clicks deeper on the microstop.
Using a dimpled piece of scrap as a gauge tends to lead to oversized holes. Also, recheck the microstop periodically - the locking ring can loosen and you can accidentally change the depth.
...Joe
Old 03-14-2009, 08:21 PM
Default Thanks
I used the < .3125 method and i think they will work out to be fine. I agree with the problem of using the sample piece; I think they will be way too big if the sample piece sits flush.
Thanks to all for the input,
John
John Johnson
Murphy, NC
RV7(A)
