Old 02-25-2009, 08:52 AM
Sid Lambert Sid Lambert is offline
Default Sticky Brakes
My brakes require me to pull the pedal up by hand so they do not drag. This is especially true after I have just landed.
My question is... Is something going wrong with the brake system or do I simply need to put a stronger spring on the master cylinder?
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 02-25-2009, 09:10 AM
JonJay's Avatar
JonJay JonJay is offline
Default Common Issue
Do a quick search and you will find a couple suggested solutions like springs and/or a continous long bolt instead of the short bolts on each side.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-25-2009, 09:23 AM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
I had a similar problem. Loosened the bolts that attach the pedals and it went away. Remember to put the cotter pin in!!
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
[COLOR="rgb(46, 139, 87)"]=VAF= Paid up 2018[/color]
Old 02-25-2009, 11:05 AM
Jamie's Avatar
Jamie Jamie is offline
I have seen people tightened those brake bolts down to 25 inch pounds or so because that's the spec for AN3 bolts. This is obviously an area where the spec is thrown out the window and a little brain power must be applied.
I had the same issue with my brakes slightly dragging (enough to groan a little) so I picked up some springs that I bought at Ace Hardware. The springs are a perfect fit and help bring the brakes pedals all the way back. Sorry, I don't remember the part numbers.
Hope that helps,
"What kind of man would live where there is no daring? I don't believe in taking foolish chances but nothing can be accomplished without taking any chance at all." - Charles A. Lindbergh
Jamie | RV-7A First Flight: 7/27/2007 (Sold)
Old 02-25-2009, 11:12 AM
My only concern is that it is getting worse. I was worried the seals may be deteriorating or something of the likes. It sounds like I just need to disassemble, clean and maybe put fresh/better springs on.
Thanks guys.
Sid Lambert
RV-7 Sold
Old 02-25-2009, 11:57 AM
Mike S Mike S is online now
Sid, two fixes usually found here.
One is long bolt, fixes any misalignment issues on the pedal pivots.
Just remember, in this usage, the bolts are actually pivots/axles, and not clamping devices.
The other is booster springs, see this thread go to post 7 for photos and parts list. In fact, read the whole thread for some good info about the long bolts.
I have done both on my 10, simple and easy.
Old 02-25-2009, 07:08 PM
dmaib's Avatar
dmaib dmaib is offline
I had my bolts overtightened. Backing them off a bit took care of the problem.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/10/2018
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 02-26-2009, 05:19 PM
ScottSchmidt's Avatar
ScottSchmidt ScottSchmidt is offline
Super Moderator
Default Skicky Brakes
How many hours do you have on your plane?
Is this something new that is happening?
What brake fluid are you using?
Scott Schmidt
Salt Lake City, UT
RV-10 N104XP (1380 Hours)
RV-12 N321UT (Sold)
Old 03-02-2009, 07:27 AM
N737Z N737Z is offline
Default put springs on Matco's
After 300 hours my brakes began to drag. The quick effective fix for me was using springs #181(I believe) from ACE hardware on the Matco shafts, but I am still going to replace the pivot points with the long bolt. Does anyone have the AN # required for the bolt?
Don
Phoenix
RV7
Old 03-02-2009, 09:44 AM
Don
Phoenix
RV7
Contact GAHCO.
