Old 02-16-2009, 11:20 PM
steve wyman steve wyman is offline
Default Section 28 : Fuel System
Here's a heads up for some of you guys who might be just starting on your fuselage kit. I have just finished section 28 ( I did part of it back in November, when I was waiting for the tailcone to arrive). If I were ever to build another of these little beasties, I would do the following: First item: Perform step 1 on page 28-06 before you install the fuselage bottom as per page 21-16- you will still have to file the washer as called for, but the entire process will only take about a minute, and will not be in your way later on. This fitting takes two folks to do if you wait til section 28 and is not the easiest to install at that point. Second item: I would heartily recommend that you consider doing the entire remainder of section 28 before you install the fuselage sides in section 23 and certainly before you attach the tailcone. All the fuel system components and lines are sort of buried and protected down in their tunnel and won't be in your way later on- this includes interior painting. Please give serious consideration to my above suggestions- you will thank me if you do. Steve
Old 02-17-2009, 01:56 AM
jamescone jamescone is offline
There is an easy way to install this fitting by yourself. First put the fitting into the hole from the rear center tunnel in the baggage compartment. Take a long nosed Vise Grip wrench and clamp it on the fitting with the 45 degree angle facing up. Then clamp the Vise Grip wrench to the bulkhead with a soft jawed bar clamp, the kind that ratchet closed. Crawl under the fuselage and install the modified washer and the bulkhead nut. It is easier to use a crows foot wrench and a short extension to tighten the nut. You can't get a socket on the nut because it is too close to the bottom skin.
The rest of section 28 is sort of a pain, but it is doable. Hope this helps those who have already completed the fuselage structure and installed the tail cone.
Jim Cone
4 peat offender
2 -6a's, a 7a, and a 12
EAA Gold Tech Counselor
Old 02-17-2009, 06:30 AM
Peterk Peterk is offline
I'm with Steve if anyone at Van's is reading. I ended up trying to do it with crows feet but even those wouldn't come far enough around the nut...ended up using the two people routine. All unnecessary as Steve says, but "doable" as Jim says.
Old 02-17-2009, 09:33 AM
You're right Jim, section 28 is "doable" when called for, but my point is that it would be much more easily accomplished, if done when I suggest. Steve
Old 02-17-2009, 09:59 AM
okiejohn okiejohn is offline
Default Sticky! Sticky! Sticky!
I sure wish these chapter hints could all be together with a sticky! They are getting buried on old posts and are too valuable to get buried. Thanks to Joe and Marty and Jim and Jerry and everyone else!
When my EAA friends came by and I had one side on, they said you need to put the fuel system in now! I'm sure glad I did, but I wish I had put the 45 degree bulkhead in before I put the bottom on!
I now am wondering about the corrugated baggage bulkhead cover (see Jerry G May 08 sun n fun photos)
Is it going to be necessary to pull the fuel tank to do an annual?
Old 02-17-2009, 12:41 PM
Bruce Russell Bruce Russell is offline
Thanks for the heads up steve, I was on my way to the hanger to install the side skins when I read your post...on my way to section 28 now.
Old 02-17-2009, 01:52 PM
Geico266's Avatar
Geico266 Geico266 is offline
I'm on section 23. Thanks for the heads up.
RV-8 : Under Contract
RV-10 : In the hangar
RV-12 : Built and sold!
RV-44 : 4 place helicopter on order.
Old 02-23-2009, 07:37 AM
Geico266's Avatar
Steve, EXCELLENT tip. Made installing the fuel system much easier without having the sides on. GOOD CALL!
If these good tips keep up I'm gonna go broke owing guys beer.
Old 02-23-2009, 07:46 AM
Mel's Avatar
Mel Mel is offline
Larry,
You never go broke owing people. As a matter of fact that just puts you in line for a government "bail-out". It PAYING UP that causes you to go broke!
A&P/EAA Tech Counselor/Flight Advisor
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 175hp O-320, 3-Blade Catto (since 2003)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 07-17-2010, 12:42 PM
Dgamble's Avatar
Dgamble Dgamble is offline
Default Read it, forgot it, paying the price
I think it was about 2 seconds after riveting on the belly skin that I remembered that I hadn't put that fitting in.
I'm paying the piper for my forgetfulness today. This is NOT easy!
Dave Gamble
Grove City, OH
RV-6 N466PG Purchased already flying - SOLD!
Built RV-12
http://www.schmetterlingaviation.com
The above web blogs and any links provided thereto are not instructional or advisory in nature. They merely seek to share my experiences in building and flying Van's RV airplanes.
