Old 02-01-2009, 07:49 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default metal edge protection
What do you call the product that some install on the edge of sheet metal, say in a lightning hole where wires or ducting pass thru to protect the parts from being cut by the metal edge. It looks like a strip of white plastic with lots of notches to allow it to flex and be put on the inside of a circle cut out.
I have some on the RV-6 I bought and would like to buy more but don't know
what it is called or where to buy it at?
can anyone help me?
Bob Martin
RV-6 0-360 C/S 1000+TT
Louisa, Virginia KLKU
Old 02-01-2009, 08:35 PM
RV10 4JF RV10 4JF is offline
I believe this is what you are looking for:
http://www.aircraftspruce.com/catalo...mmetedging.php
Noah's Avatar
Noah Noah is offline
Grommet is the general name.
Also, "Edge Grip", "Trim", "Plastic edge trim". Try McMaster.com
Highest Regards,
Noah Forden, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men… for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 02-01-2009, 09:15 PM
crusty
Caterpillar grommet.
These folks carry it http://www.bonaero.com/default.htm
Click "inventory", then "electrical", scroll down to "Gaterpillar Grommet"
I have also fount it at electronic supply stores----real MilSpec stuff even.
EAA 512
Old 02-02-2009, 05:44 AM
Bob Martin's Avatar
Default That's it!
Thanks guys!
I was surprised to see it in ACS catalog.......I've looked at that book for hours
and hours.......I think I didn't know what I was looking at! Amazing!
Thanks again for the quick responses guy!
Bob Martin
Old 02-02-2009, 04:03 PM
jchang10 jchang10 is offline
Also, available from van's. I just ordered some the other day.
MS21266-1N 12" long edge grommet
#40533 RV-10
10/19/2011 First flight
11/26/2011 Phase 1 Done
2012 First Oshkosh 3200nm, 20 hours, 209gals, 9.7gph, 152kt RTavg
2012 My first Burning Man fly-in! Can't wait for next year!
Old 02-02-2009, 05:24 PM
crusty
Default Just a heads up,
This stuff comes in different sizes to fit different thickness of metal.
The -1 is for the thinnest, higher -# is for thicker, check the chart in the link I provided earlier.
I had to use -2 for some of the wiring in my ten.
EAA 512
Old 02-03-2009, 04:45 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Two different types of edge...
...protection are being discussed here, and not identified well...
The link above is to the more usual, and cheaper, edge protection that looks like a u channel with slits cut in the side. It is a single plastic (or nylon or polyethelene) extrusion/molding.
http://www.gen-aircraft-hardware.com...df/ms21266.pdf
The Aircraft Spruce link (post #2) above is much more expensive due to a very different construction method. As described at Aircraft Spruce...
The product is a composite of polymer encapsulated spring stainless steel enhanced by a protective cushion.
It will grip the edges of the metal and will flex in a much tighter radius.
This spec. sheet has better visuals than AC Spruce...
http://www.devicetec.com/DTIProducts...92Brochure.pdf
I find the cheaper "catapillar" plastic ones (in nylon) work fine on large lightening holes, etc. - but if you want edge protection on a portion of a straight edge, or are dealing with complex cut out shapes, then nothing can beat the more expensive AC Spruce product.
They are vastly different products that perform similar functions.
Gil Alexander
RV-6A VSB (Very Slow Build)
Grumman Tiger N12GA - flying
