wrongway john
I made a comment on another thread which is closed, and besides this needed another thread to it anyway since it was off topic, but it had to do with me thinking that props should make good bird shedders and would probably make them mince meat before they hit our windshield.
To which another replied, that a propeller does nothing to protect us from birds. Particularly at high speed. In the 360 deg space covered by the propeller the blade cord only covers a very small portion of it. With the relatively slow RPM the propeller turns, a bird can easily get through without being hit.
I wanted to learn more about this, and if my simple calculations are accurate enough, it appears I?ve had a false sense of security about my prop being the ultimate bird shredder after all.
Here is what I?ve come up with. To make things simple, I allowed 180 mph for the plane, and 20 mph for a bird coming at you head on which would give us 200 mph to work with. That puts both the plane and bird at 293 feet traveled per second on a collision course.
With a prop turning, say, 2,400 RPM?s, that would be 40 RPS (revolutions per second). But since the prop generally is two-bladed, we can double that figure, which will give us 80 swipes of either blade of the prop hitting the bird in that one second of time. But the bird is going to go through the prop area in a small fraction of a second, so I used 8 propeller swipes in a one-tenth of a second time to hit the bird while the plane and bird traveled 29.3 feet or nearly 3 feet in one-hundredth of a second time. Not sure what figure to use here and won?t do anything further with it since it already seems the bird can get through quite easily. The length of the bird would only give slightly better odds of hitting the prop, but still everything seems remote. What do you think?
If this is pretty much accurate, the next question is, how well do the windshields hold up on bird strikes?
wj
wj
