flyingbeaver26
I wanted to share my design of some casters I made for my rv-8. I have a 1 car garage so putting the plane up on wheels would prevent me from being able to slide the fuse from side-to-side. Plus, it makes the fuse a little lower to the ground and easier to continue to work on. I bought a 4' piece of AL angle at Home depot, cut to length, and bolted these casters on. each caster is rated to 250#. I had to re-drill the mounting holes as you may notice once I got it sitting on the gear. I also used a couple of extra washers to level the caster so that it would swivel easily. The axle is mounted on the inside so that I could use the stock AN4 bolt for this assembly.-Brad
