CFI1513840
I just read about an incident involving a fire in an RV-8. Fortunately, it happened on the ground and both occupants were able to exit the aircraft safely. The fire was extinguished in a timely manner by ground personnel. The problem was traced to a loose B-nut at the firewall.
This brings up the point of safetying B-nuts. Obviously, Vans thought it was necessary for the fuel tank pickup tube and issued a Service Letter, but what about all the other B-nuts?
Are there some special circumstances that make only the fuel pickup tube prone to loosening? Why not safety all B-nuts? Would loctite be a possible solution? I realize that there are thousands of airplanes flying around with unsafetyed B-nuts, but knowing that fact would be little consolation if your airplane is on fire.
