I decided to intall an engine fire suppression system in my RV-7A after reading an article about fire extinguishers in the August 2008 issue of Kitplanes. I was also inspired by another RV builder who kindly shared his ideas with me. Lots of hot-rod car builders put these engine compartment sytems in their cars, but interestingly, not a lot of homebuilders put these systems in their planes. Fortunately, it appears the likelihood of an inflight engine fire is very low, though I've never seen any statistics on it. Perhaps this is the reason we don't see many of these systems in small piston powered aircraft?
I called up Safecraft, a company referenced in the article, and ordered their AS model. This included the cylinder with 3 pounds of halon and all the hardware, including 3 identical spray nozzles. Each nozzle sends a spray in 3 directions, an arc of about 150 degrees. I dispensed with their supplied steel fittings in favor of AN aluminum fittings. Total weight with everything is about 4.5 pounds.
I chose to mount the cylinder horizontally on one of the panel ribs, adjacent to the firewall. This location meant it would be out of the way and from a practical standpoint not affect my CG. If you choose to mount in the same location, be sure to ask Safecraft for the old style head--their new style head is longer and will not fit in this location. Also, if you choose to mount the bottle horizontally, ask Safecraft to install an internal pickup tube in the cylinder.
Before mounting, I riveted a piece of 0.040 to the rib to act as a reinforcing doubler. Since my plane was already built, this mounting task turned out to be a lot more work than I expected. I spent countless hot hours on my back under the panel! On an under-construction RV, this task would be extremely easy.
After this task was completed, I ran aluminum tube to the engine compartment. Safecraft recommended 2 nozzles forward of the baffle and 1 nozzle behind the baffle. For the transition from the stationary engine mount to the moving engine, I used Aeroquip 303 hose.
I am pleased with the quality of the Safecraft product. I hope I never have to use it! By far the hardest part of this project was simply getting over the mental hurdle of adding more weight to my airplane. In the end it was $400 well spent, in my mind cheap insurance.
Paul
Paul
