Due to space limitations I had to start a new thread.
More of my really dumb ? and answers from:
http://www.vansairforce.com/community/showthread.php?t=33181&page=2
Dumb ? #23) How do I machine countersink the sub spar assembly?
Answer: Make sure to use the 1/8" (#30) 120 degree countersink. Practice on scrap aluminum first. Hold the stop with one hand against the aluminum to keep the stop from spinning, while drilling with the other hand. One author recommends using a lower speed and higher pressure than drilling, not to exceed 2500 rpm. Whatever combination of speed and pressure used, the goal is to avoid chattering which will result in an uneven surface and irregular depth. A drop of machine oil may extend the life of the countersink bit. It is important to maintain the angle once you start drilling and avoid "wobbling." If the drill is not perpendicular to the hole, it will appear eccentric. Just clear the loose aluminum, reset the angle and drill again. Once the depth was set on the practice aluminum, I took a 2X4 and essentially match drilled three holes into the 2X4 near the center. I then enlarged the center hole in the 2X4. I clamped the 2X4 to the EAA table and cleco-ed the sub spar assembly to the 2X4. I then countersunk the hole over the enlarged hole in the 2X4. I did need to drill a few "sets" of holes to accomodate the variable spacing in the flanges and the ends of the flanges. Be aware that both the lock nut AND/OR the plastic stop can become loose and contribute to irregular depths.
Dumb ? #24) How do I generate enough pressure to repeatedly squeeze AN470 AD 4-4 rivets?
Answer: After hand squeezing a few of these rivets, my arms started to fatigue. I found it a lot easier to start the rivets using hand strength and then complete the task by resting the straight arm of the rivet squeezer on a wooden stool, using body weight to accomplish final rivet compression.
